Single Pallet Chair
Intro: Single Pallet Chair
For this Instructible, you will need a minimum of one pallet, one hammer and one hand saw. You can use more than that (screws, drill, varnish, new nails, et cetera) but it's more of a challenge to use the minimum of materials and equipment.
This project was made as part of an installation in Cuge Le Pins, France. The installation can be seen here: http://errorists.weebly.com/error-bibliothegraveque.html
STEP 1: Cut the Pallet in Half
Well actually don't cut it quite in half; cut it lengthwise right after the blocks...see the pictures if this statement doesn't make sense.
STEP 2: And Again...
You're going to want to cut the slightly-less-than-half pallet section on one side of the blocks again so that it is divided into a 45/55 split.
STEP 3: Destruction/Construction
You can completely dismantle the smallest portion of pallet for boards.
Take the slightly-more-than-half section from your last division of the pallet and connect it under the blocks of the biggest pallet portion. Add two boards (which you should have removed from what was the smallest portion of pallet) for legs.
STEP 4: Everybody Needs a Little Support.
Add a couple, or a few, of those spare boards to under where the seat of the chair rests on the back/legs.
STEP 5: Add 2 Boards and You're Done!
Add two more boards (from that smallest portion of the pallet which you dismantled) to connect each fore-leg to it's corresponding hind-leg.
Now you've finished; well done! you now have yourself a sturdy and rustic-looking chair made from a single pallet.
7 Comments
Pignanelli 10 years ago
This is what I call "backgrading", or using a "dirty" item for a "clean" use, and should be avoided more than "downstreaming", where you would recycle a "clean" item for a "dirtier" use (say a salad mixing bowl into a chemical mixing vat).
If we can't do this, the inevitable results are cancers and disease, as neat as the project might seem... but it is a common problem that faces all engineers in every phase of modern design, manufacturing, recycling, product development, public works, etc.
Proceed with caution and forethought! =D
Error Collective 10 years ago
gitemstevedave 10 years ago
kminer49er 10 years ago
Pallets with no IPPC stamp are domestic use pallets and are safe for human contact. Treated pallets are only used for import/export freight. 99% of pallets used for export/import are Heat Treated. These are heated to achieve a minimum core temperature of 56 °C (132.8 °F) for at least 30 minutes. Pallets treated via this method bear the initials 'HT' near the stamped IPPC logo, (see below sample logos below. Heat treating is not only safer, but cheaper.
Fumigated pallets were treated with methyl bromide. Pallets treated via this method bear the initials 'MB' near the IPPC logo in place of the 'HT.' Since March 2010, the use of Methyl Bromide as an acceptable treatment has been banned.
Treated wood pallets must be stamped on two opposite sides indicating either HT for heat treated or MB for methyl bromide treatment. Leave the 'MB' pallets alone.
Justin Tyler Tate 10 years ago
Penolopy Bulnick 10 years ago
