Single Wheel Transport.
Intro: Single Wheel Transport.
I have seen some one wheeled devices around and this is my ideas of using a single wheel as transport. The overall diameter is 600mm and can be ridden with a foot either side of the wheel so you are facing forward or could be ridden sideways with both feet inside the hoop, a bit like a skateboard. All the designs have been done on autodesk 123D Design.
The main wheel is the motor its self, the magnetic hub as a tyre around the outside and the coils on the inner rim which you stand on. The large diameter of the motor means that it will have a relatively high torque for the power put in. It will also allow more room under the feet supports for batteries.
To support the outer rim without a center shaft, there is two rows of rollers around the outside of the inner rim, this means the rim has lots of support and so will hopefully be highly durable.
The turning of a one wheeled vehicle is just done by leaning, like on a skateboard or similar, to stay upright the gyroscopic force of the spinning tyre is used like on a bike. To stop tipping over backwards or forwards while riding electronic gyros can be used to control the motor and add stability.
The batteries that power the whole system would best be lithium batteries. The are expensive but coming down in price. The batteries will be housed in the foot support with a charging port on the side and charger built in.
As you are riding there will be a hand grip control that will control the throttle, display battery level and sensitivity of the gyros that keep it stable.
The bulk of this can be made out of 5 or 3 mm aluminum plate, the rims would be cast aluminum with cast resin around the outside for the coils to be set into. On the outer rim it could either be a cast plastic or a rubber tyre on the aluminum rim with the magnets glued or cast in.
The rollers could be ball races on a shaft with no modifications needed.
Please vote for This in the 123D design Challenge for people under 18.
20 Comments
ejb 9 years ago
People have made the steering work and at high speeds too
e.g.
KorpseGrinder 10 years ago
benmurton 10 years ago
Melia Esperas 10 years ago
Possibilities to overcome lack of steering:
1) Use parts of the vehicle (ie Battery) to lean with the rider, giving you more influence over the wheels tilt
2) Use one wheel but wide enough in width, that you can include two separate bladders inside the tire (Left/Right) then use the rotation of the wheel to compress air and have the bladders be inflated/deflated to the distort the overall shape of the tire to help steering.
3) Have three wheels very close so it looks like one wheel and:
a) Have their speeds vary
b) tilt/stagger them in relation to each other to effect steering using mini hydraulics or pneumatic devices.
c) use the rotation of the wheels to produce compressed air that is then used for air brakes to slow down one of the wheels, or the forces from the compression of the air itself slows one of the wheels down.
I'm very iffy on the the third possible solution. But the first two aren't setting off any red flags.
Have fun!
TooIngenious 10 years ago
sdaupanner 10 years ago
randomray 10 years ago
The difference is you have more weight or mass, so your influence over the wheels of a skateboard or unicycle in much greater.
With a one wheeled vehicle you don't have as much influence since you are a small rider inside the much more massive wheel, the faster it spins the less influence you'll have.
schel 10 years ago
a motor cycle for instance... forks on the battery/motor base/drive , same on the rear.
no chain...no gas tank nor engine taking up heavy frames eh? Uh-huh...you can have that one...on the house.
Gabord18 10 years ago
E Major 10 years ago
ArtisanEclectic 10 years ago
It also shows that Ben is on the right track about the lean-steering.
Don't let this deter you Ben. You were on the right track.
Thanks.
Kiteman 10 years ago
