Here Is My Build
21,158
254
9
Introduction: Here Is My Build
About: Family Man, Veteran, Woodworker, Novice Boat Builder, Library Card Holder, and Lifelong Learner Always trying to learn through reading and pursuing a different path than most. Through understanding consumers…
here it is
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
Step 12:
Step 13:
Step 14:
Step 15:
Step 16:
Step 17:
Step 18:
Outside Contest
Outside Contest
Be the First to Share
    • Back to School: Student Design Challenge
    • Halloween Contest
      Halloween Contest
    • Cheese Challenge
      Cheese Challenge
    9 Comments
    robolimbo
    robolimbo
    7 years ago on Step 18
    What type of skin are you going to put on the boat?
    C_D_SPURGEON
    C_D_SPURGEON
    Reply 6 years ago
    Sorry it took me so long to reply, its going to have a Dacron skin. This is the same material used is some ultra-light or experimental aircraft
    Jobar007
    Jobar007
    7 years ago on Introduction
    It might be an optical illusion, but your keel looks to be hogged. You should check to see if there is a curve in your keel since a hogged boat is no fun to paddle (doesn't turn well and inefficient in going straight). Sometimes you can make that go away if you pull the gunnels together after it is off the form. I'm not sure what the designer had in mind with that regard since I'm not familiar with their build process.
    Having and using a boat is freeing. It allows you to go places that you could only dream about before... Welcome to the brotherhood.
    C_D_SPURGEON
    C_D_SPURGEON
    I still have some bracing to add also, I will check that out though when I get home. Thanks for the heads up!
    Unfortunately I am more and more addicted to the idea of using this one, I look forward to making more.
    MR_NATE_H
    MR_NATE_H
    7 years ago
    military? What branch are you in.
    C_D_SPURGEON
    C_D_SPURGEON
    Reply 7 years ago
    AF, I was SFS for 15 years now training for Communications
    MR_NATE_H
    MR_NATE_H
    Reply 7 years ago
    Wonderful. I'm joining the Marine Corp next year.
    C_D_SPURGEON
    C_D_SPURGEON
    Thanks, I hope to be floating by the beginning of August
