Skull Pumpkin
Intro: Skull Pumpkin
STEP 1: Pumpkin Shopping, Permanent Marker
You'll need to hunt for your pumpkin in a place with weird-shaped pumpkins, which (as I mention in my Life-Size Skeleton instructable) probably isn't your local supermarket...
You need a pear shaped, head-sized gourd. It can be shaped like a pear or a lightbulb, as long as it's got a nice round chunk where one might keep one's brains, and a narrower area that might serve as a jawbone. Often a pear-shaped pumpkin will be a bit skewed to one side: these are especially good for our sinister purposes.
Pick up the candidates. Recite some Shakespearian Yorick-related verses. Think "skull." If at some point this process gives you either the willies or the creeps, then you've probably found the right pumpkin.
Take it home and rub your hands together, cackling, and bust out your permanent marker.
Draw out your shapes, using photos, toy skulls, or actual skulls if you have them laying around.
STEP 2: The First Cut Is the Deepest
Now, scoop out the brains.
It's impressive how skull-ish your creation can look immediately after this step!
STEP 3: Think "Planes..."
In "2-D" pumpkin carving, you can just cut out a hole and you're done. But here in 3-D land, you want to finesse it a bit: make angled cuts into the eye as shown in the photo. You'll still end up with a hole for the eye, but the angled surfaces you've created help to set up the other parts of the skull.
Same idea with the jaw: thinking sculpturally, use shallow cuts (you can always go deeper later) which "imply" depth, because they look like they are "in front" of other features.
Barely scrape off the skin on the highest surface of the cheekbone, but dig all the way in underneath it. there is an almost triangular "hole" created by the middle of the jaw (see photo). Again, use reference materials to get the surfaces right.
STEP 4: More Planing
Notice: the eye hole in this photo looks kind of odd. Leave it that way for now; the final shape of that hole is where most of it's personality lives, so it's really a "final touch."
STEP 5: Start Smoothing
Do that first, then use the dull edge of your knife to press down the pointed edge. Pumpkin cooperates well with this; it smooths right out and looks nice and bony.
Now, do the eye. Slight variations in the shape of the eye really affect the skull's "attitude," so carve carefully. Shoot for either good symmetry, or extreme asymmetry; anything in between sends a muddled message.
STEP 6: Finish, and Display!
If you peel it all off, nobody can tell it's a pumpkin... if that's one of your goals, so be it. Otherwise, I suggest leaving a bit of skin, stem... it's a few notches more disturbing that way.
Make a stand with a CD/DVD spindle, some crumpled plastic bags, and some black duct tape.
Or dangle your skull from a wire.
Or, place it on top of your complete skeleton.
Candles don't do much for it really, but that conventional pumpkin technology works too.
I've had these decay in a few days, and last a year when dried properly...
Happy Carving!
25 Comments
mikecraghead 5 years ago
Hi folks! I wrote this 'ible 11 years ago, and after a decade of practice and an appearance on Halloween Wars, I wrote a whole book on pumpkin skulls, and 3D pumpkin carving in general. More info here: https://mikecraghead.com/card.cfm?id=65&full=1&pag...
Cheers!
sze arteest 11 years ago
beewhitlock 13 years ago
mikecraghead 13 years ago
mr.squeakers 13 years ago
drummonkey92 16 years ago
mikecraghead 16 years ago
Actually, any fruit or vegetable that's solid has a bit of an advantage over a pumpkin, because you can get the relative depth closer to reality. A pear would work great because of the fact that it is... wait for it... pear-shaped. Of course it's not easy to find a pear the size of your head.
"what does it say in the orange writing on the second picture of the last step?"
...I lifted that photo (of one of my skulls from a few years back) from extremepumpkins.com, rather than digging it up on my machine: Pure laziness really. And I can't quite make out what it says either; maybe it's just a funky dental pixellation?
ThaNorwegianDude 14 years ago
BuffaloNickel 14 years ago
w_nightshade 15 years ago
Kaiven 14 years ago
St0ney 15 years ago
fancypenguin845 16 years ago
meritsetgo 16 years ago
byoho 16 years ago
Chris Bilton 16 years ago
