Slide Action Pistol
Intro: Slide Action Pistol
slide action pistol I made works well have fun
some stats
rage 20 -25 feet with good rubberbands
comfortable 7-8 shot mag
ammo grey 1 slot connector
don't forget to rate and subscribe if you get stuck or something like that comment and ill get to it as soon as I can
rate subscribe comment please
some stats
STEP 1: Piece List
Gather Knex
Conectors
Orange 23
Yellow 38
Red 12
Green 2
Grey 1 slot 8
Grey 2 slots 6
White 6
Rods
Green 85
White 28
Blue 13
Yellow 1
Long black 1
Others
Y clips 7
Conectors
Orange 23
Yellow 38
Red 12
Green 2
Grey 1 slot 8
Grey 2 slots 6
White 6
Rods
Green 85
White 28
Blue 13
Yellow 1
Long black 1
Others
Y clips 7
STEP 2: The Slide
build the slide
pic 1 build and gather everything you see in the photo oh and there should be 7 blue rods one fell on the floor when taking the slide apart
pic 2 add 5 blue rods to the first side
pic 3 add one of the orange layers
pic 4 and the second side
pic 5 add the last orange layers
pic 6 add the last side
pic 7 what it sould look like from top
pic 8 make this part
pic 9 another view
pic 10 add blue rod through were shown
pic 11 add blue rod through shown
pic 12 add together
pic 13 final piece
pic 9 another view
pic 12 add together
pic 13 final piece
STEP 3: Handle and Trigger
just follow
pic 1 make everything you can see in photo the one in the middle right the green rod should be on the end
pic 2 add rod on first layer
pic 3 add second layer
pic 4 add third layer
pic 5 add fourth layer
pic 6 add final layer
pic 7 add four whit rods as shown
pic 8 make what you can see
pic 9 attach on handle
STEP 4: Magazine
the easy bit
pic 1 make all in photo
pic 2 add four white rods on first side
pic 3 add orange sides
pic 4 add last side
pic 4 add last side
STEP 5: Body
probably the hardest step out of all
pic 1 make what's in photo
pic 2 add internals to first side
pic 3 add other side
pic 4 on the white connector the blue rod should be on the bottom right how shown now not how it is on the other photos
pic 5 should be 5 layers on the white connectors
pic 6 make what's in photo and put aside until assembly
STEP 6: Assembly
this bit is easy just follow
pic 1 and pic 2 connect the handle as shown
pic 3 add sides as shown
pic 4 add blue rod
pic 5 add the black y clip as shown
pic 6 and pic 7 add the slide to the top
pic 8 clip on the mag
pic 9 make the firing pin
pic 4 add blue rod
STEP 7: Baning the Gun and Loading
follow this is very easy if followed correctly
pic 1 put rubber band on firing pin and attach to pic 2 here as shown
pic 3 also need a rubber band from here to pic 4 here the back of the slide
pic 5 also need rubber band on the front as shown but needs to be small
pic 6 also need a band for the trigger as shown
pic 7 and pic 8 how to load put bullet into mag and the put mag pusher and then attach a rubber band as shown
to shoot
to shoot the gun pull the slide back until trigger moves upwards and the push slide forwards and then pull trigger repeat until reload
thanks have fun with the gun :) ;)
to shoot
29 Comments
jayjay2845 9 years ago
It took me a long time to get it to work but it did work in the end
belkinboss248 9 years ago
what is th ammo and how exactly does the clip work i am confused
bxmx918 12 years ago
aleceatsfood 13 years ago
juri53124 13 years ago
matthew9090 13 years ago
tylamarre 14 years ago
knex mad 14 years ago
KnexFreek 14 years ago
DJ Radio 14 years ago
mettaurlover 14 years ago
StarkIndustries 14 years ago
alfpwns 14 years ago
