Introduction: Sliding E.Piano/Keyboard Stand for DAW
Need to move your keyboard forwards and backwards under your desk for use with your digital audio workstation? I did! So here's my solution: PVC pipes cut to size around the bottom metal poles of my keyboard stand. I then attached felt fabric to the pipes and wha-la! It took about an hour. Here's a step-by-step with pics. But first, here's what you need:
5' PVC pipe
PVC pipe cutter
Tape Measure
1 Yard of felt fabric
All purpose spray adhesive (from an auto-store)
Sand Paper
Scissors
Box cutter/knife
Black acrylic paint/paint brush
Step 1: Measure Each Leg
Measure from the inside of the rubber cap to the center beam. Each leg may be a different length (all four of mine are).
Step 2: Measure the Diameter
This will tell you how thick your PVC pipe needs to be. I ended up going with 1 1/4".
Step 3: Purchase PVC Pipe
Step 4: Take Rubber Caps Off :)
This may be the hardest part as it required great strength and dedication. But they all came off :)
Step 5: Cut Your Pipes
Measure off and cut the pipes
Step 6: Sand the Pipes
This will help the felt stick better to the pipes
Step 7: Attach Cloth
Get your cloth set up/cut to size. Use spray adhesive and roll on to cloth
Step 8: Cut the Ends
Cut the ends with the box cutter, use the scissors to clean the edges.
Step 9: Paint the Edges
Paint the edges. I also painted on the inside of the pipes about a half inch around.
Step 10: Put It All Together
You're done!
3 Discussions
4 years ago
This is really great. You've inspired me to try assembling a long IKEA Linnmon table with Olov adjustable legs so that my keyboard can fit underneath. I was originally going to use furniture sliders underneath the keyboard stand, but this looks more elegant.
Reply 4 years ago
is this the 59'' linnmon table top from IKEA, btw? http://www.ikea.com/us/en/catalog/products/20251356/
5 years ago on Introduction
