Smart Plant Watering
4,709
53
6
Introduction: Smart Plant Watering
About: Computer engineer.
Hello! Using this project you can water your plant/s automatically considering external temperature, humidity and light. Also you can use this as a home weather station and check temperature, humidity and lightness from your cellphone or computer just using a browser..
Are you leaving on vacation and nobody is available to water the plants.... This project will help you!!
Requirements:
  1. PCB
  2. ESP8266 NodeMCU
  3. DHT11 sensor (Temperature & Humidity)
  4. Relay
  5. Light sensor
  6. Box / Container
  7. Headers
  8. Water pump (12V)
  9. small diameter transparent clear soft hose (may vary based on your water pump connectors)
I am still working on some aspects of this project and making some adjustments. This is a working version but I plan to add new features. If you have any recommendation, please comment!
The following steps will help you to have your first smart plant watering prototype ... Feel free to add your comments/suggestions. Thanks!
Step 1: Use This Schematic and Test It on a Protoboard
Follow schematic and replicate this into the protoboard...
you need the following items:
1. Protoboard
2. ESP8266 NodeMCU
4. Relay
5. Light sensor
6. Water pump (12V)
7. small diameter transparent clear soft hose (may vary based on your water pump connectors)
Step 2: Working on the PCB - Weld Headers for ESP8266 and Sensors Based on Schematics
If you already tested the circuit on a protoboard, now we can move this to the next stage.. Let's use a PCB and weld headers for the esp8266 and sensors. Wiring of them is on the back...
Note: If you see the back of the PCB... welds are not very good but consider this is the first prototype... if you have suggestions/comments... please feel free to add them :)
Step 3: Insert ESP8266, Sensors and Relay
Insert ESP8266, sensors (DHT11 and photocell) and relay (5v) into the headers... (I think that you can weld them directly to the board... but I preferred to use headers to easily remove them if needed).
Tip: for the Light sensor connection I used heat shrinkable sleeves for the cables so the photocell's pins are protected from movements.
Step 4: Preparing the Water Jerry Can & Water Pump (12v)
You can use any water jerry can you have. I have used a 10 litres water jerry can so it has enough autonomy for a couple of weeks.
The water pump is 12v (1A) so I connect it directly to an external power source.
Step 5: Loading the Code & Test It
You can use Arduino IDE to program your ESP8266 (NodeMCU).
Please get latest code version from this repository: https://github.com/eplx/esp8266-Plants-Watering/tr...
The first time you load the code, the device will work as an AP and you will need to connect to this WIFI network for further configuration:
SSID: 1SmartWaterPlant
Password: water
Then, you can access the device from any browser using the following:
http://YOUR_DEVICE_IP:8356/html --> check status (Temperature, Humidity, etc)
Note: you can get your Device IP Address looking at the Serial Monitor output from the Arduino IDE.
Be the First to Share
    • Anything Goes Contest
    6 Comments
    the_stro_cks
    the_stro_cks
    Question 1 year ago
    Thank you for sharing this good assembly. But I have some question.
    Is there any other choice but to input the USB power port to operate the WiFi module?
    Is there a way to operate the whole circuit using the inserted 9V battery?
    If you give some advice, I would be very grateful...
    StephaneL28
    StephaneL28
    4 years ago
    Hello,
    thank you for this assembly that I find very convenient.
    I only have a small network problem, I entered the SSId and the password, it appears in my network manager under Windows 10.
    But impossible to recover an IP address via the arduino serial monitor.
    I do not understand my mistake, and if you could help me this will be super nice.
    Thank you.Hello,
    I do not understand my mistake, andHello,
    Thank you.if you could help me this will be super nice.
    Thank you.Hello,
    Thank you.
    StephaneL28
    StephaneL28
    Reply 4 years ago
    Sorry for my post above, which split
    EstebanP27
    EstebanP27
    Reply 4 years ago
    Hi Stephane, good finding. Seems I mistakenly removed the IP address from the serial output in the lastest version. I have just fixed it and updated the in the repository. Please download the new code version and it should work fine now. Thanks again for your feedback!
    DIY Hacks and How Tos
    Cool system. What kinds of plants have you used it for?
    EstebanP27
    EstebanP27
    Reply 4 years ago
    Hi, I'm using it for exterior plants. Currently I'm using it for a rose plant.
