Snow Globe That Makes Real Snow
Intro: Snow Globe That Makes Real Snow
If you really think about it, snow globes are one big lie. They don't even have real snow! I decided to fix that by making a snow globe that makes its own real icy snow! It uses a snowman shaped piece of aluminum, some peltier elements, some resistors to create condensation on the aluminum and produce snow.
Check out the video!:
STEP 1: Watch the Video!
You'll get the best idea of what it does by checking out the video. Don't forget to subscribe!
STEP 2: Basic Idea
The peltier elements are able to transfer heat from one side to the other when a voltage is applied. Using this effect we can make a really cold side as long as the hot side stays cool enough.
STEP 3: Mount the Peltier Elements
I used 3 different sized peltier elements and 3D printed a mount to put them on the CPU cooler. The largest one will be directly mounted on the CPU cooler then cascading in size to the 3rd. They will each cool the next one slightly more than the last. You need to use thermal paste on each pelter to get good thermal conductivity.
STEP 4: Test Out the Coolers
You want to make sure you can get to very low temperatures. I was able to reach -25C on the smallest peltier element. Which is good enough for this project.
The two larger peltier coolers were able to take 12V directly while the smallest one was able to do 5V. The PC power supply can supply each of these voltages.
PC power supplies require one of the pins to be ground to turn them on. There are plenty of articles showing how this is done.
STEP 5: Machine/create the Snowman
I decided to make a snowman looking shape, but you could really use anything, even just an aluminum rod. I used my lathe to remove all of the material that wasn't a snowman.
Then used my mill to remove some of the base to make it sit perfectly on the peltier element.
I also 3d printed a hat and added a ribbon for a scarf. (hat file included)
I used a torch to heat the snowman and press the hat into its head so it would sit properly.
STEP 6: Create a Mount for Snowman
You need to wire up the resistors in parallel to also hook up to 12V. The 75R resistors @ 12V will produce 1.8W of heat. These will get really hot, so be careful!
Using the bottom lip of the snowman I created a second mount to press it into the top peltier element. You will again need to use thermal paste to mount it. Then tighten down the screws to secure it to the base.
STEP 7: Mount It in a Box or Create a Housing
I decided to lasercut a housing for everything. I used acrylic and mounted the fans to it. This held everything up and out the top, this is where the "snow globe" will sit. Hiding all of the other things. Everything will be controlled by the power supply, and once its turned on it begins running. No microcontrollers in this one!
STEP 8: Cut the Felt
You need the felt to hold whatever liquid you decide to vapourize. I cut it out on the lasercutter but this can easily be done with scissors. It needs to go around the snowman and sit on the resistors.
STEP 9: Moisten the Felt
You need to get the felt moist before placing it on the resistors. I use water for the ice!
STEP 10: Add the Snow Globe Cover
The snow glove cover will trap the moisture and allow the cold snowman to collect it and freeze the condensation. It will continue to grow as long as there is vapour in the chamber. It may fog up if there is too much water, but you can easily take off the cover and wipe it with a paper towel then place it back down.
STEP 11: Turn It On!
Power it on and watch the snow build!
STEP 12: Support Future Projects!
If you enjoy these project, please consider subscribing to my YouTube Channel:
https://youtube.com/seanhodgins
and if you really want to help making these projects to be free and open source, consider becoming a patron!
5 Comments
g00dhum0r 2 years ago
maker_soup 2 years ago
pierrecarles 2 years ago
wannabemadsci 2 years ago
Suggestion: 3D print some coal pieces to create a face and buttons. A carrot nose would be nice too!
Thanks for building it and sharing!
Ranuga 2 years ago
