Snow Plow Tilt Adjuster (John Deere 325)
Intro: Snow Plow Tilt Adjuster (John Deere 325)
STEP 1:
STEP 2: Bent the EMT to Go Around the Nose of Your Tractor Add the Hole.
STEP 3: Make a Mount for the Tilt Rod.
STEP 4: Make the Pin Lift Cable Bracket.
STEP 5: Make a Piece to Hold the End of the Cable and Slug to Pull Up the Pin Release Lever.
STEP 6: Make a Handle to Pull the Cable With.
STEP 7: Cover the Brake Line to Keep Water Out.
I found some cool rubber belting to keep water off the cable. Otherwise it will run down into the sheathing and freeze.
STEP 8: Thank You!
If you are a maker like me you like buying yourself awesome new tools
and supporting instructables like this one. You can do BOTH by checking out the #MADEINUSA branding irons I make that allow you to burn your fully custom logo into your finished work. Check out my shop at http://yeltrowshopllc.com – THANK YOU – yeltrow
