Soap Box Derby Cart
Intro: Soap Box Derby Cart
This a simple soap box cart that my son and I built for my 9year old daughter so she could enter the Trowbridge Carnival Soap Box derby
STEP 1: Basic Frame
We used planed softwood, 2.1m x 74mm x 18mm for the frame and 2.1m x 50mm x 18mm for the front axle. The king pins for the steering will be M10 x 100mm bolts
The cross brace at the front is 400mm as is the the brace that forms the "radiator" whilst the rear is at 600mm
The wooden pole is from a beach wind break and is used to estimate where the driver will be sitting.
The body frame work is made using 25mm x 25mm softwood and its size was based on my 9yr old
STEP 2: Bodywork
Cheap, fine plywood.
In order to minimise waste and keep costs down the frame was wrapped in craft paper. We used this to calculate how much ply was needed.
The paper also formed the templates for each panel
The wheels, again just as a guide
The grill, seat and floor are made from pieces of chipboard I had lying around in my shed, you might also notice that the dumb irons at have been shortened. I thought this improved the proportions of the cart.
STEP 3: Steering
After much experimentation the steering system finally consists of:
1. Steering wheel from an old games console
2. Steering column made of tubular clothes rail
3. A bicycle front crank
4. two 15mm brass plumbing equal T pieces
and a couple of go-kart track rods bought from e-bay
In one picture you can see we used the bike chain to check we had the frame, king pins and steering square.
The tube was cut in half and a another piece found to fit snugly inside. the was clamped using U bolts so that we created a rudimentary collapsible steering column. One end bolted to the steering wheel and the other welded to the bike crank.
Ultimately the crank was drilled to allow the track rods to be fitted, creating in effect a Pitman arm.
STEP 4: Finishing
Simple brakes were added the act directly on the rear wheels, some lights, a horn and some wings for the front wheels.
The whole thing then finished off with green and yellow paint. The racing numbers are created using white sticky back plastic and red insulating tape for the No 7.
15 Comments
Hunterpecora 1 year ago
Jack The maker3 7 years ago
How did you make the brakes, you never specified how you made them.
GarethMorris 7 years ago
i. a simple push operated bar that acts on both rear wheels, a simple pivoted pedal connecting to a bar acting on the front of the rear wheels.
ii The second method was bike brakes, a wooden batten fixed in front of the rear wheels cable operated in the same way as on a bike. The brake lever mounted to the cart body. If you use a go cart steering yoke then the lever may fit straight on to the yoke.
Jack The Maker2 7 years ago
is there space behind the seat because I need a place to put an engine.
would a V6 solenoid engine fit?
guidess 8 years ago
Beautiful! Thanks so much for the plentiful and super clear photos, especially the close-ups of the steering arrangement. Makes this really doable!
GarethMorris 9 years ago
That looks fanatastic, I love the steering wheel
a5tor 9 years ago
244 Jake 10 years ago
Your project does bring back some good images of family and friends.
Thanks and best of luck!
Big Jake
GarethMorris 10 years ago
Gareth
longwinters 10 years ago
(From a dad of two grown girls)
bhardy6 10 years ago
chuck the canuck 10 years ago
Penolopy Bulnick 10 years ago
