Sociable Tandem Cargo Trike
Intro: Sociable Tandem Cargo Trike
If you like our trike and think it's a winner, cast your vote for our project!
The link is right up there at the top right.
This side-by-side, or "sociable" tandem trike was conceived and built so that two friends could sit next to one another, pedaling and enjoying the scenery. To share conversation and beverages. Drink holders are an obvious feature, but let's look at what this particular SociableTandemCargo Trike has to offer.
- Adjustable, semi-recumbent, side by side seating.
- Shared steering wand with solar stereo option.
- 15 speeds to choose from.
- Disc brakes on all 3 wheels, and a parking brake.
- A seat and cargo area in the back, that will carry 150 lbs. of whatever you choose.
- Roof rack with bungie hooks for light items or a solar panel.
- Standard parts, wheels and components whenever possible, to make this easy to build and fix.
This Instructable is for intermediate/advanced "Makers," who already have a working knowledge of metal working, bike building, basic engineering, and woodworking skills. It took us about 4 months from start to finish. There are 2 of us, but we did not work every day on this project, mostly weekends.
If you need more specific instructions, or have questions about where to get materials, visit us at Pineapple Trikes, our FaceBook Pineapple Trikes page, or email us.
Let's get started!
STEP 1: Design Your Sociable Tandem Cargo Trike
STEP 2: Acquire Your Materials
General Materials List
Metal:
20 feet of 1" round tubing
20 feet of 2" round tubing
20 feet of 1 1/4" round tubing
small piece of 1/4" flat metal
1 sheet expandable metal mesh
10 ft. of 3/4 inch emt
Wood:
1 sheet of 1/4" plywood
1 sheet of 1" plywood
Recycled bike parts:
One front end of a bike, trimmed down to the headset, head-tube and forks.
6 bottom brackets - 2 with viable pedals, cranks, bearings, etc.
2 twist-shifters for the back derailleurs
3 disc brake assemblies
3 sets of caliper brake mounting assemblies
2 sets of "suicide shifters" for the front derailleurs
6 complete chains
Assorted:
zip ties
para-cord
pop-rivets
6 - 4" long -3/4" bolts, washers and nuts
washers
shade cloth
brake cables, stops, cable ferrule ends and sheathing
shifter cables, stops, sheathing
Paint and Finishes:
about 3 cans of metal primer spray paint
about 6 cans of whatever color you will paint your trike.
*optional: 2-Part Epoxy finish, such as "SmartGlaze."
STEP 3: Tools, Equipment, Workspace and Expertise
This is where we re-iterate that you should be an experienced builder to attempt this Instructable. We are assuming a working knowledge of metal and wood. We hope you have a space, albeit a garage, to work in so that your project stands a chance of surviving the elements. Our shop is an E7-Up, but we face many extra challenges because of all the dirt and exposure.
You will need a welder- we use a wire-feed MIG. A tubing-roller and a conduit bender are also going to be essential. We use this one from Harbor Freight. Tables, sawhorses and tarps can also be instrumental.
You need to have basic wood and metal shop tools including: angle grinder, jigsaw, hacksaw, sawsall, pliers, socket-set, sander, drills, bits, wire brushes, wire wheels, a flap disc, grinding wheels, cutting wheels, etc.
STEP 4: Bend Your Tubing
If you don't have a tubing roller or emt bender, you can go to our other Instructable, "How to bend metal without expensive tools."
If you've got a CAD model, getting dimensions is straightforward. If you built a physical model, such as our wire model, here's a handy formula for calculating your curves: measure h (the height of the chord) and c (the length of the chord) and solve for the radius of the circle with
r = (c^2 + 4 h^2)/8h
One of our curves is 3" high (h) and 48" long (c). Here's the size of that radius:
r = (48*48 + 3*(4*4))/8*3
r = (2304 + 48)/24
r = 98"
Make a template with a 98" radius and you can hold it up to your tube as you bend it for comparison.
Here's a tip for not making corkscrews
STEP 5: Lay Out and Weld Up Your Frame
Because this is a large frame, you will need a couple of large tables to set up your frame. We used yardsticks, masking tape, and other props to function as a jig, for holding our frame pieces together.
A great rule to follow is to tack all the pieces together before you weld anything all the way. That way, you can make sure things line up, and are fairly symmetrical.
Cut and weld bottom brackets to the frame.
STEP 6: Adding Adjustable Wheel Dropouts
In order to adjust the wheels so that they stayed parallel, we attached a home-made tensioner, made from a hardware store turnbuckle, attached to the wheel, and to a bolt welded to the frame.
STEP 7: Make and Attach Jack Axles to the Frame
This will get the chains to line up with the wheels. We used heavy duty tires that are used by Yuba bikes for their Mundo model. The spokes are heavier than regular spokes, and the tires are rated for around 300 lbs. apiece.
STEP 8: Attach Seat Runners to Frame
For our build we realized that the headset from a BMX bike was the perfect size to hold a seat tube (28mm diameter.) Our seats, with their 3/4 inch bottom seat support fit nicely into the handlebar clamp. The result is a solid, adjustable mounting point to accommodate different lengths of rider's legs.
STEP 9: Seat Construction
We found this guy online, (Seat frame construction, by Barnett Williams,) and followed his plans. The seats are brilliant!
STEP 10: Welding on the Disc Brake Attachments
We cut out a flat metal pattern that the disc brake can screw right into.
You might also be able to find forks that already have disc brake attachments on them for the front, but will have to attach metal for the back. We repurposed caliper brake attachments, because they took the same size hex nuts as the disc brake attachments.
STEP 11: Build the Non-heirarchical Steering Tiller
Measure the distance from where you will sit in the seats, with your arm comfortably extended, to the headpost. You will want to bend the tiller into the shape seen in the photo, above. We used emt, with two crosspieces in the front. One is for attaching to the headset, and one is for attaching a light. We also reinforce our tiller with expandable metal mesh. It is nice for strapping on mini solar panels and stereo stuff.
STEP 12: Shifters, Brakes, Cables and Sheaths
Attach cables and sheath with zip ties. When you get them all working the way you want, weld on some cable stays in strategic spots, then you can run the cables without zip ties after you paint the frame.
STEP 13: Build the Roof Rack
Build the roof rack, weld in 3 frame attachment points and sew a cover that can be cinched on with paracord.
STEP 14: Build the Back Cargo Seat
Frame the back area up with EMT, on a metal mesh base. We made a removable box, bolted on to the frame in 4 places. Weld washers onto the frame, and you can drill guide holes, and then pop rivet the plywood on.
The plywood is treated with 2-part Bar Top epoxy. Smart Glaze is one brand that we like. We painted the glaze over the wood and the frame, as a protective coating.
STEP 15: Design a Great Color Scheme
The simplest way to get an amazing color scheme is to borrow one from Nature. Choose a lovely bird, flower or butterfly and copy not only its colors, but also how much of each color as well as noticing how those colors are arranged.
Here, with some liberties taken for simplicity, is an Adelpha Californica's scheme revealed: it's overwhelmingly a rich chocolatey brown (around 70%), with (in descending proportions) cream, orange and gun metal blue/gray (most of the remaining 30%). A hint of red and black finishes it off. Especially important to notice is that not all the colors are "allowed" to touch. Orange only touches brown, while black touches red and brown and gray. Following these sorts of rules nails the "Wow" factor.
For our trike, we took inspiration from Buckeyes and Fritillaries.
Go right ahead and swap yellow for blue, or red for brown; the important thing is to create a consistent set of rules for your bike (or other project)
STEP 16: Strip the Trike, Prep and Paint
Strip all the parts off the frame, group and label them so they can be put back on easily.
Grind and wire brush all the rust and slag off the frame.
Prime with a decent metal primer
Paint with a few coats of spray paint, and let cure, optimally in the fresh air and sun.
After a day or two, brush on a layer of two part epoxy. It will put a clear finish over your color that will make it glossy and with stand bumps and scrapes better.
This rattle can and epoxy paint job cost about $100. Here's a great video about how to paint with a rattle can.
37 Comments
NathanSellers 9 years ago
Captain Robert 9 years ago
Thank you! Yes, we've entered it! Please vote for us! :)
This trike is very comfortable. Sitting like a normal person instead of perched up on your bones is quite pleasant.
Thanks!
Wow, your Batman costume is amazeballs!
https://www.instructables.com/id/Batman-Costume/
petermix01 8 years ago
Hi, I found your design very interesting.I liked it and I'm looking forward to make one myself. I realized you haven't say which metal you used for the frame. Was it steel, aluminum or other? Please let me know. Thanks
jwinston3 8 years ago
So I'm curious about the drive system and spindles. What did you use the spindles off of? I dont see anything about them listed in your parts list. I'l love to learn a little more about how you built that part
Rubeus Hagrid 8 years ago
Have you been to the Maker Faire in the bay area?
Captain Robert 8 years ago
DIY Andrea 8 years ago
This is absolutely amazing, I entered in contest with my trailer and my vote goes for this project! Congrats!
Thank you for the kind words, Sir!
Jim Weeder 8 years ago
I saw 150 lbs for cargo. What about combined rider weight? My wife is losing weight but is at 350 lbs right now and we want to use this to help her lose faster, but if her weight is not going to be allowed I guess we will have to stick with walking.
We briefly carried four adults on the trike the day we also carried the clown. Everything seemed just fine. Total weight carried was in the neighborhood of 650 pounds. I've also ridden in the back area while two adults pedaled it and that seemed completely stable: no strange popping or creaking sounds (I've broken spokes on overloaded bikes so I know what impending doom sound like), so that would be a combined weight of over 550 pounds.
We are using Yuba Mundo wheels. Yuba claims the Mundo can carry 440 pounds plus the rider. I've no idea what the proper weight distribution should be on a Mundo, but 60% of the weight on the rear wheel doesn't seem unreasonable. We have, in effect, two rear ends of a Yuba cargo bikes. Can we carry 60% of 880 pounds plus riders? That could be in the 750 pound range. The trike has three wheels, so can it carry at least 50% more weight than a Mundo, which could be as much as 900 pounds?
Unknown. The challenge is that bikes never experience lateral forces on their wheels. When a trike goes around a corner, the rims have to absorb a force they aren't really designed to absorb. We did some clever things with the wheels to make them survive this kind of force, but this is still an off-label usage.
There's undoubtedly some vector analysis someone smarter than me could do to figure out when the wheel could fail. My intuition, as we've used this trike, is that under normal conditions (normal road slopes, typical driveway angles, average speeds around corners) we at least match the Yuba Mundo rating of 440 pounds plus a rider.
So yes, you and your wife won't break it. Plus you can carry your groceries.
Plus it's way more fun to ride alongside with your partner instead of wondering where they could have possibly gotten off to.
SCHLEPIC 9 years ago
I was hoping for some depth into the design and construction of the frame and the drive train. So the yoke lever is essentially the brake lever, actuating all three brake cables? It's a great looking trike.
Oh! Yes, the yoke activates all three brakes simultaneously, just like the brake pedal in your car activates all its brakes at the same time. The yoke also carries all the shifters. It makes for a really easy system to use, as well as to route the cables.
If you're a bike rider, you know that we generally use the front brake more than the rear. About 80% of the stopping power is from the bike's front wheel.
I've done two things to control the activation of the brakes. I've tuned the front calipers to close fractionally later than the rear brakes. I also gave the front brake slightly more leverage (by installing its attachment point further from the yoke's pivot than where the rear brakes attach).
In use, what happens is the rear brakes grab first. This can help control your downhill speed. As you pull a bit more, the front brake grabs. When you pull hard, the front brake grabs the hardest, mimicking the behavior of an experienced bike rider's use of two braking controls.
SCHLEPIC 8 years ago
That sounds fantastic. Consider adding more pictures when you have the time!
I understand that desire! I have to admit we've left some fun stuff out of this 'ible. We are hard at work getting our next vehicle ready for Maker Faire and a big race at the end of the month, but we also wanted to publish sooner rather than later.
I'm slowly adding more information as time allows. We are intentionally keeping this 'ible as more of an overview, since there are so many good recipes to build your own contraption available on the wwweb, and each builder's design satsifies a different set of needs.
I'll add some details about our design constraints and goals that drove the shapes and engineering.
Great. I look forward to seeing it.
