Social Distancing Arduino Monkey
Intro: Social Distancing Arduino Monkey
This project was designed to help with social distancing. This monkey can be worn pin/necklace that lets you know when someone is getting too close for social distancing.
Parts:
- ATTiny 85
- HC-SR04 Ultrasonic Sensor
- LED (red)
- 330 Resistor
STEP 1: Code and Pin Connection
The setup is fairly simple. Just connect the ultrasonic sensor and the led to the attiny. Detail are in the code below. I recommend testing it on an Arduino Uno then moving to the ATTiny85.
/* * Original Ultrasonic code by Rui Santos, https://randomnerdtutorials.com * Modified by Peter Fox Flick for attiny, peterfoxflick.com * VIDEO: https://youtu.be/dF5E5jsWSZA Ultrasonic sensor Pins: VCC: +5VDC Trig : Trigger (INPUT) - Pin 0 Echo: Echo (OUTPUT) - Pin 1 GND: GND LED Schematic Pin 2 -- LED -- 330 Resistor -- GND */ int trigPin = 0; // Trigger MOSI 0 int echoPin = 1; // Echo MISO 1 int ledPin = 2; long duration; long dist[3]; int pos = 0; void setup() { //Define inputs and outputs pinMode(trigPin, OUTPUT); pinMode(echoPin, INPUT); pinMode(ledPin, OUTPUT); } void loop() { // The sensor is triggered by a HIGH pulse of 10 or more microseconds. // Give a short LOW pulse beforehand to ensure a clean HIGH pulse: digitalWrite(trigPin, LOW); delayMicroseconds(5); digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // Read the signal from the sensor: a HIGH pulse whose // duration is the time (in microseconds) from the sending // of the ping to the reception of its echo off of an object. pinMode(echoPin, INPUT); duration = pulseIn(echoPin, HIGH); // Convert the time into a distance dist[pos] = (duration/2) / 29.1; pos = pos > 2 ? 0 : pos + 1; //use a rolling average to help prevent spikes long sum = 0; for(int i = 0; i < 3; i++){ sum += dist[i]; } long avg = sum / 3; if(avg < 200){ digitalWrite(ledPin, HIGH); } else { digitalWrite(ledPin, LOW); } delay(500); }
