Soda Tab Chain Necklace
Intro: Soda Tab Chain Necklace
First of all I would like to credit krazy glu with the whole concept. This is how to make a necklace with soda tabs.
Materials
Loads of soda tabs(100+ probably)
A large safety pin
Multitool
Materials
A large safety pin
Multitool
STEP 1: Start Collecting
You're going to need ALOT of soda tabs. I used 94 tabs, but my neck is really small so you should probably get as many as possible. I would say 100+.
STEP 2: Cut N' Bend
Now you're going to need to cut the soda tabs so you can put them together. So take your multitool and select your pliers. I think the best place to cut is the little crease in the tab. Refer to the first picture for futher explaination on the crease.
Cut 4 tabs on the same side then bend each one. Try to bend the same amount for each one.
STEP 3: Connect N' Bend
Now take 8 cut tabs and seperate them into two piles of 4. Slip one set of 4 into the uncut part of the other set. Refer to the picture for futher explaination.
Now bend the cut part back on the set you put through the hole.
STEP 4: Make the Clasp
Add links to the chain until it will fit comfortably around your neck.
Now take your safety pin and your multitool, and cut the pointy part off of your safety pin so that you don't accidently stab yourself while putting on the necklace.
Put the safety pin through the hole at one end of the chain and put the other part through the other end.
STEP 5: AND BAM!
Now you have an awesome necklace. Now go out and have strangers ask you about it.
49 Comments
3366carlos 10 years ago
lisz 11 years ago
pancho del rancho 14 years ago
Takena Bako 14 years ago
War on 45 12 years ago
Since aluminium cans contain water or similar liquids, you can deduce that aluminum does not rust.
nerfer192 13 years ago
dinglballs 14 years ago
Solderguy 14 years ago
eulaliaaaa! 12 years ago
MakeLifeColorful 12 years ago
J@50n 14 years ago
He has 92 stay-on-tabs and one safety pin.
Great job counting!
hollowthekiller 12 years ago
joelr97 12 years ago
baneat 15 years ago
paqrat 13 years ago
