Solar Bike Stereo
Intro: Solar Bike Stereo
In this instructable I will show you how to make a solar powered bike stereo box that fits in a milk crate, which you may already have on your bike! This instructable assumes you have some proficiency in woodworking and soldering, and is really about the solar to battery circuitry and the options it provides. This system could be used for any variety of applications that run off 12v DC.
In designing this project the box went through many phases, first it was battery powered, then the solar was added, and more extra bits kept finding their way into the box. Because of this the photos will appear somewhat inconsistent, so I have provided some easy to read drawings for clarification.
STEP 1: Materials
Parts you will need:
wire
car speakers
solar panel (Sunforce 5watt trickle charge)
milk crate
mdf
tompsons water seal
polyfil
milk crate
DPDT switch
M-F Audio Cable
Power jack and plug (to match whatever your amp comes with!)
8 threded inserts
assorted screws
Tools you will need:
Soldering Iron
Table saw
Clamps
Screw driver
Drill
STEP 2: Cut List
I used 5/8" MDF and my box is waaaay heavy, you could easily do this with 3/8" or 1/2" MDF to save some weight but it will change the dimensions of your sides bellow.
Cut sides:
1: 12" x 12" bottom
2: 12" x 9+7/8" sides
2: 10+3/4" x 9+7/8" speaker sides
1: 13" x 14" top
1: 10+3/4" x 9+5/8" divider
STEP 3: Speakers
Cut holes in the center of two of your sides to match your speakers. You can use a hole saw if your speakers are small enough, or drill a small hole and use a scroll or jig saw. Solder about a foot of wire onto the speaker terminals and screw them onto the inside sides of your speaker sides so that they fit on the holes you just made. You can round over the outside edge of your holes with a 1/4" round-over router bit.
STEP 4: Glue Up
Glue the sides and speaker sides together to make a box. Glue the diver in the middle flush with the bottom. Finally glue the bottom on the box. (You might want to make sure the box fits the crate before you glue it up, you may need to shave a 1/16" off all the pieces depending on the accuracy of your crate.) Should look like the picture when viewed from the top.
STEP 5: Fit the Top
For the top, put four of the threaded inserts into the top corners of the box and drill through holes that line up on the top. The top should over hang about an inch past the back. The top should also be the same size as the solar panel. Mark the mounting holes from the soler panel on the top and install the other four threded insterts on those spots. You should now be able to screw the top onto the box, and the solar panel onto the top. I used 1" 10-32 square drive machine bolts for all of these. You can optionally add a 1/8 pice of plexy glass with the same mounting holes as the solar panel on top of the solar panel to protect it.
STEP 6: Connectors
Layout the holes for your power input jack, audio input, and switch on the front side of your crate. Make sure they align with holes in your milk crate, I used one of the handle holes for everything. Drill the holes and install the parts.
STEP 7: Solder
Solder everything to the switch based on this schematic. What this all does is let you switch between running the amp of the battery versus running the amp off the included AC adaptor while the solar cpanel charges the battery. This is important becasue you don't want the solar panel charging the battery while the battery is in use. If the box is not connected to AC putting it into AC mode serves as a generic off mode, but the battery will still charge. The solar panel comes with alligator clips; I just cut those off to use the wires. All of the grounds (black wires) can be soldered together, just the positive (red) wires have to go through the switch.
At this time you might want to consider any other possible uses for 12v DC. For instance, you could add a 12v car cigarette lighter outlet to power any accessories you hay have for one of those. I took apart a 12v car to 5v usb adaptor and added that to my box so I could charge my usb capable accessories. (You could even charge your ipod while it plays over the speakers.) Just connect any 12v additions to the power cable that goes to the T-amp.
If you can, use speaker wire or some other shielded wire as it will cut down on the likelyhood of all your cables becoming antennae for background noise.
STEP 8: Cables
Connect all the cords and speakers to their appropriate inputs on the amp / bettery / solar panel. You can run the cables over the divider since it is 1/4" short where needed.
STEP 9: PolyFill
The battery should sit in one speaker well and the amp in the other. Fill the remaining space loosely with poly fill. The divider prevents the speakers back noise from canceling each other out, and the polyfill keeps the back noise from bouncing back out the front of the box.
STEP 10: Assembly
Put on the lid, panel, etc. And put the box in your crate. Finish with Thompson's Water Seal. Won't be really waterproof, but will help if you get caught in the rain.
STEP 11: Control
I use an iPhone mount on my handle bar and run a 1/8" to 1/8" sterio audio cable along my brake cables to the box.
STEP 12: ROCK & ROLL
You're done baby, and now you've got a stereo system that can rival any car's, but mounted on your bike! Sweet!
Get the Tunes Remote or Tango iPhone app and your friends can easily DJ music on your device, great for parties.
The Boom Bike was made possible by generous support from the ASU GPSA Graduate Research Support Program.
23 Comments
bcasey5 10 years ago
http://youtu.be/T8SBgIgDz_Uhttp://youtu.be/JORVvdxj4Ck
Heres a couple vids on the one I built.
I kept it a bit simpler than is shown in the site by leaving the switch off. I used Velcro to mount the amp and used its volume and switch. I have not built the lid yet but plan to make 2, one plane and the other with the solar panel.
I'm not using the solar panel most of the time because the battery will last a couple days so unless I'm camping with it, I don't think it will be too useful. I also want to keep the weight down. I'm not completely done with it yet. Im considering adding a phone charger in there and might use a cigarette lighter (male/female) setup as for it.
iApple guy 12 years ago
eastonj 13 years ago
mbmosher 13 years ago
you've inspired me to create my own. i do not have a bike yet, but i frequent the beach and the wilderness so this is F***ing fantastic! thank you and keep up the good work!
worth125 12 years ago
If your amp is drawing 2 amps and you have it hooked up to the battery (not charging), then the battery will supply the full 2 amps---simple.
If you are charging your battery at the same time that your amp load is on, then your panel will supply .375 amps (optimally) and your battery will supply the remaining 1.625 amps.
Now for the BUT --- If your amp is on for too long and your battery can't supply the necessary current, then the amp might start trying to suck more power from the solar panel than it can provide---potentially causing overheating and damage to the panel(?).
PV arrays on houses are hooked up to batteries that are constantly being used, so I don't see there being any problem with charging a battery while there is a load attached. House arrays have better backup systems like a charge controller or a generator that can kick in if the batteries are getting too low. Since we probably don't want a generator in our milk crate we'll just have to mind our battery a little more closely.
Also, am I correct in interpreting that there is nothing attached to the negative terminal on your battery?
Thanks!
mbmosher 12 years ago
LemurX 12 years ago
AMP678 13 years ago
$60 - solar panel
$50 - Amp
$20 - Battery
$70 - Speakers (Car audio I recycled from another project)
$20 - Other stuff (wire, switches, MDF, etc)
$220 - Total
But you could probably save a bunch using different speakers
bjrcboy 13 years ago
ciaran.mooney 13 years ago
thank you in advance!
crazybuthappy 14 years ago
