Solar Mobile Phone USB Charger
Intro: Solar Mobile Phone USB Charger
This is a solar mobile phone charger that uses old car charger to produce electricity enough to charge your phone
Charging on the go will never be so easy.Keep walking and the solar power station will charge your battery while you walk in the sun.This is helpful for travelers in the desert.An Emergency power backup may help save a life!
STEP 1: Materials Required
Materials Required
- 12 v battery
- Solar panel with battery charger
- Old car charger or new one starts from $ 1 +
STEP 2: Connecting Solar Panel
Connect the solar panel to battery charger
Charge the battery ( I used a old 12V 7Ah) used UPS battery
.Attach the battery backup(I'm using Mi Battery Backup) to the micro usb.
2.Put the setup into your backpack..You can also use a tiny box to encase the charge controller. Now insert the usb into the power supply and charge your device while you travel and walk.
STEP 3: Connecting to Charger
Remove the cover of old USB car charger
Solder the wires (positive and negative) to the charger
Use a connector to connect the wires to old battery
Use the USB cord to connect to the USB port to charge your mobile phone
STEP 4: Use It
Now use it by placing the solar panel in light and watch the magic.
The disadvantage of this method is that until you have high intensity of sunlight it would not work.
