Introduction: Solar Ni-cad or Ni-mh Battery Charger.
hey guys i broke my wrist this instructable took awhile lol. anyway this is a way to charge 2 batteries of your choice using the sun!
every material used as recycled
if you like this instructable please vote for it in the epilog '09 contest
i used my scanner to get this pic.
Step 1: Materials:
-an old broken solar calculator to take apart for the solar cell.
-a side style 2 cell AA battery holder buy one or get one from an old kit or electronic device that is broken.
-a diode - just an ordinary diode NO LEDS THEY WASTE POWER
-wire
-a volt meter or multimeter
Step 2: Disection
take out the screws from your solar calculator.
cut the 2 wires leading from the circuit board to the solar cells, give your self room to work with.
Step 3: Voltage Check
check the solar cells voltage using your meter, make sure the cell is in direct sunlight when your measuring it.
if its 3 volts use a 2 cell AA holder
if its 1.5 volts use a 1 cell AA holder
simple
Step 4: Wiring and Soldering
uhhh this is easy
the red wire on the cell goes to the diode and then the red wire on the holder
the black wire goes to the other black wire
solder all this together
Step 5: Glue the Solar Cell
glue the solar cell so that it holds onto the battery holder in a way where it will face the sun while staying still.
Step 6: Done!
this takes a while to charge 1-3 days for a full charge depending on the Mah
3 days for 2500 Mah batteries
1 day for 1000 Mah batterries
Have fun.
Epilog Challenge
27 Comments
14 years ago on Step 6
OK, this takes a while to charge them, but how to you prevent overcharging and killing the batts?
Reply 14 years ago on Step 6
You'd have to create a charger circuit, i just monitored my batteries every 2 hours with a charge meter (Measures charge) i was trying to make it as small as possible so i didn;'t add one.
You get a better reading if you let the batt sit for a hour or more so the ions can realign.
Ah right, thanks for that.
10 years ago on Step 6
I think you would get best reading after letting the batteries set for at least an hour. The ions would have time to realign.
13 years ago on Introduction
Thank you for making this so simple! I do have a question though, does a diodes forward voltage drop mean that the amount is lost? and why is this, is it higher drop if the diode can take more voltage or what? the only diodes I could find in my house have a peak inverse voltage of 50v and a forward voltage drop of 1.6v at a forward current of 1amp. thank you
Reply 12 years ago on Introduction
You do lose that Voltage. Most will recommend a schotkey diode because forward voltage loss is only .15 to .45 volts. They can be had for pennies on ebay
would this circuit have any problem fitting inside a lightbulb with a photo cell and led? and would it have any problem powering the led???
Reply 13 years ago on Introduction
The circuit is very small, it will fit in most things, such as a light bulb, even smaller, it should be able to power several led's but i can't be sure without building one myself, but i lost my device =(
Hi, nice job.
I would like to know what is the current rating of the calculator solar panel.
Hmmmm, i never did an actual test, but i can estimate about 83 maH
Ok, as i test mine and obtain around 20ma with a light source an A/C bulb.
Thanks for the information.
I know now that in sunlight i can have more.
13 years ago on Step 6
you could use 2 or 3 cells to make charge time 1 day!
Thing is - a calculator's solar panel produces a miniscule amount of power. I think it would take months to get one full charge. (self discharge aside)
14 years ago on Introduction
Will it damage a NiMH battery if you continue to supply power to it after its charged?
Reply 14 years ago on Introduction
yes, but not to the point of battery leakage.
can it still be used or will it function noticabley less if i use it and recharge it repeatedly?
I recommend checking on the batteries from, time to time.
Hi. Does the diode protect the solar cell from being damaged as the voltage of battery rises? I'm working on something similar & noticed that it's hard to find diodes w/ forward voltage drops of less than 0.2V, which can be significant. I'm wondering what would happen if we just hooked the solar cell directly to the battery ... ?
The diode keeps the batteries from discharging into the solar cell when the lights go out.
