Solar Power System
724,747
891
179
Introduction: Solar Power System
This instructable will show you everything you need to put together a pretty good sized electric solar panel system. Things you will need:
Supplies:
Solar panels
Charge controller
Battery charger
2 AWG cable
At least one 12 Volt marine deep cycle battery
Mechanical lugs
1 power inverter
1 Rubbermaid tote or other container
1 battery charger
Tools:
Cable cutters
Red electrical tape
Screwdriver
Drill
Crescent Wrench
Gather supplies and lets get started.
Step 1: Preparing the Batteries.
The first thing you want to do is charge your batteries with a charger. This will insure they are charged to capacity and ready to go at set up. I purchased my batteries new and were only at about 60%.
While the batteries are charging, you can set up the solar panels and get them wired up and ready to go.
Step 2: Place Batteries in Container.
Once the batteries are fully charged, place them in the container and. Make sure all the positive (+) terminals are on one side and negative (-) on the other. Once in place, measure from terminal to terminal to make the jumpers.
Step 3: Creating the Jumpers.
Next, we want to connect the batteries in parallel. To do this, Make some jumpers out of 2 AWG cable.
Note: Make sure to size your jumpers for your system. If you want to use a larger inverter you will need to use larger cable. 1200 Watts/12 Volts = 100 Amps. Depending on where you look, 2 AWG cable is good for around 100 Amps. If you want to run say, a 2400 watt inverter, you should use 2 cables per jumper.
Measure between terminals and cut cable to length. Then add the mechanical lugs. Since the battery terminals were a bit bigger than the holes in the lugs I bought I drilled them out to fit.
Step 4: Preparing the Lid
Now, add some holes in the lid to run the wires for the charge controller and the inverter. I wanted the charge controller outside so it was visible. You could just as easily put it inside the container for a more concealed look.
Step 5: Connecting the Charge Controller and Inverter to the Batteries.
Next we connect the charge controller and the inverter to the batteries. You will want to make sure the inverter is turned off and the charge controller is not connected to the solar panels yet.
Step 6: Final Set Up and Test.
It should all be wired together. All that is left is to connect the charge controller to the solar panels and turn the inverter on and check to see that it works.
Step 7: Some Final Thoughts.
I originally made this set up as a back up power source for when the power went out. But, I think I will use it more often than that. I don't think the solar panels are powerful enough to charge the batteries after depleting them every day. I will use it for a few days and update how well the system charges with constant use.
I originally tested out a single battery and was able to run a lamp and my laptop for about 5 hours before I finally shut it off. The good thing about this inverter is it will shut off automatically if the voltage drops too low to prevent depleting the batteries. I'm pretty confident that with the three batteries I will be able to power larger items for an extended period of time.
Also, this is a pretty expensive set up, about $650. My costs (with out tax or shipping charges) and where I got things.
Solar panels $250 (used from craigslist)
Marine batteries $240 (for 3 from Walmart)
2 AWG Cable $5 (for about 2 feet from Lowe's)
Lugs $8 (for 8 from Lowe's)
1200 W inverter $130 (Amazon.com)
I had the rubbermaid container, battery charger, and the charge controller came with the solar panels. I don't think it unrealistic to spend around $700 or so, possibly more depending on how you set your system up.
Depending on how this works I will most likely upgrade to some better solar panels, increase the solar panel array size, and get some more batteries.
If anything is unclear please post comments/questions and I will be more than happy to update.
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    • Big and Small Contest
    179 Comments
    Everett_Edge
    Everett_Edge
    3 years ago on Step 3
    If you are claiming that teachers (or parents) can use this to teach people how to do this, you need to explain HOW to hook up the batteries. You say 'connect the batteries in parallel' .... But IF a teacher doesn't know what or how to connect the batteries in parallel, then this is of NO USE.... Please be more detailed in the future.
    BioT
    BioT
    Reply 8 months ago
    It's sad... As an elementary & middle school student in the mid-1970s, this was part of what was taught in most regular science classes. When I decided to get my teaching degree in the mid-90s, even many of the previous year's Ivy League grads couldn't put together a wire, battery, and flashlight bulb in a way that made it light up (without several incorrect tries first, at least)!
    RichardW61
    RichardW61
    Question 2 years ago on Introduction
    Looks like the harbor freight panel set. Is it? That would help figuring out what the solar watts is. Thanks!
    GodsonK
    GodsonK
    Question 3 years ago
    I really want to know how many batteries and solar panels and type of inverter I need to supply a house with 17.5 Arms appliciances.
    KhanyisoD
    KhanyisoD
    Question 4 years ago on Step 1
    Hi I have Wagga espresso machine which is 3400w.I would like to know, if this inverter Solar power system batteries can work for me?
    13415
    13415
    7 years ago
    I want the set up a small cabin and run a refridgerator,hot water heater and maybe a light. What size panels and how many batteries and what size invertor etc. Would i need ? Just a ruff guess would be apreciated ! Thanks!
    BugsyDoss13
    BugsyDoss13
    Reply 4 years ago
    The only thing really to worry about is how much wattage you're pulling out and how much is being replenished. I currently run a 1000 Watt system 10* 100 Watt panels with a 10 battery battery bank. With a cobra 1500 Watt inverter. I have had no problems so far running a deep freeze, a refrigerator, 12 volt lights, and multiple TV's. Just make sure you're putting more power back in your power bank than you're pulling out. Hope this helps.
    MatthewI10
    MatthewI10
    Reply 5 years ago
    You would not want to run an electric water heater off of PV. That woudl be a complete waste of solar panels. Better to get a set up where the sun heats the water directly and supplement with chemical fuel. You can get super efficient LED lights that are very bright and only use like 12W of electricity. You might only need 200w of panels.
    LauraO60
    LauraO60
    Question 4 years ago on Introduction
    Hello: I'm interested in making a solar power system like the this one. The design didn't include a battery bank. Not that familiar yet with everything, but it's really interesting and we want to power an outdoor water feature. I see solar kits out there that have solar panels, a submersible pump and a rechargeable battery, but none last long and they don't even store power as the feature is being used so max. and ongoing capacity is never created. If I make one that has the inverter, I don't have to use a solar wired pump and can actually use it for other AC purposes. Thanks!
    SyedA233
    SyedA233
    Question 5 years ago
    Hi Dear,
    Can you please Advice me How many panels in need for three battery's? how may Volts battery should i buy? plz give me the complete list of products i required to make this solar system.
    Thanks & Regards,
    sam
    Harikrid
    Harikrid
    Thanq so much
    & I didn't get clarity of this system expense totally.
    So please send me total how much money I needed to do this experiment..
    Mklouda
    Mklouda
    5 years ago
    I thought for sure you were going to spell it out to me how to connect that inverter and charge controller to the battery because I needed spelled out to me am I putting them connect them to the same terminal so they're touching each other I appreciate it cuz I've been looking for this answer for days and finally I'm going to post my own question thank you in advance
    ArwaGuesmi
    ArwaGuesmi
    5 years ago
    Hi, you have helped me understand to a great deal. I need your help actually, I'm building the same system to power a laptop and a monitor with a smart charger.
    this charger will run on solar and the grid and the batteries deriving power from both sources as necessary.
    Any ideas how I should link these two systems?
    John Stark
    John Stark
    6 years ago
    Thanks to its very useful information and great achieving solar energy the sun to produce energy reduce our dependence on nonrenewable fossil fuels, inevitably combatting the output of greenhouse gas emissions into theair.
    http://www.worldsolarpanels.com/
    poorveshm
    poorveshm
    6 years ago
    Hello,
    Kindly provide details of components, like the volts, amps, amp hours, watts, size, brand, cost & vendor
    1) Solar panels
    2) Charge controller
    3) Battery charger
    4) Invertor
    joserosa12
    joserosa12
    6 years ago
    Great and informative post. You described each point clearly and strategically. Installing solar power system is helps to reduce pollution by capturing energy of the sun, In this way it is helpful to protect the environment.
    Thanks!! https://powur.com/jose.rosa/learn
    FoRPAN
    FoRPAN
    6 years ago
    Useful Information
    RyanC168
    RyanC168
    6 years ago
    I have been struggling with this forever. All I want to do is use my 5v panel to charge my 1.5v NiHM triple A batteries. Seems like it kills every battery, they start out low at 1.0V and then after I use the panel with + to + - to -, with a diode on the negative lead.
    What am I doing wrong?
    MichaelG282
    MichaelG282
    7 years ago
    Not sure what all you got for the $250.00 but if it was just 4 solar panels and the charge controller you paid a bit to much. Those appear to be Harbor Freight panels from their kit. http://www.harborfreight.com/45-watt-solar-panel-... It usually runs about $135.00 when on sale and it includes 3 - 15 watt panels, charge controller and some lights.
    I have 2 of these kits set-up connected to 3 RV/Marine deep cycle batteries from Les Schwab Tires, I plan to add some more panels but am going to get larger wattage ones since this only runs about 4 days of night time use to run my Cpap machine, a 60 watt light bulb and a small charger that puts out 2 USB outlets for charging my phone and spare "30,000mAh Dual USB Portable Solar Panel Power Bank" that I carry when away from home, the AC stuff is running off a 2,000/4,000 watt inverter from Harbor Freight, after 4 days I fire up my small generator and run it for 8 hours or so powering a battery charger while my friends and I either watch a few movies or play D&D.
    AmyLuthien
    AmyLuthien
    Reply 7 years ago
    Your link is incomplete, but I found it anyway: http://tinyurl.com/45-watt-solar-panel-kit-10-pc
    Either way, the sale price for this item is $199.00, and it only has 3 panels, so $250 for 4 panels is actually cheaper by $4/panel than Harbor Freight is offering. ;)
