Solar Powered Lighting for My Home.
Intro: Solar Powered Lighting for My Home.
The first priority when I conceived my home to be solar powered was to ensure I always had lights. In the darkness it can be scary yea? Maybe not. Anyhow I wanted lighting that does not suck the life out of a battery bank like a tick does with blood.
Before we continue please take a look at my battery bank instructable to understand how I stored my energy.
https://www.instructables.com/id/Lifepo4-solar-storage-battery-bank/
Also the switching between utility and battery power is shown in this instructable.
https://www.instructables.com/id/DIY-Circuit-breaker-panelboard-with-Automatic-Tran/
As always, all my instructables are overviews of how I chose to safely implement my idea. If they don't satisfy your needs then you have to do you own research. Any technical questions I'm more than happy to answer for You.
STEP 1: Photovoltaic Panels to Harvest Sunlight.
There are oem and diy methods to secure photovoltaic panels. The choice will be up to the owner.
STEP 2: Using the Most Efficient Lighting Device.
Once you talk efficient lighting, led is the champ. Forget incandescent and fluorescent. For the same lumen output led will always consume less watts. For me, most of my rooms use 4watt or 9watt depending on the room size. It's your preference on how bright you want your rooms and outside lighting.
Leds come in standard base sizes and 120volt so they are quick and easy replacements for other bulb types.
An important note about leds, they need cooling. Putting them in a sealed fixture is not recommended for maximum life.
