Solder on PCB Traces
Intro: Solder on PCB Traces
Have you ever needed to solder a component onto an already completed PCB, or wanted to fix a broken trace or even mod something like a gaming controller? Well here's how!
STEP 1: Supplies!
You won't need much for this instructable, just the basics.
You'll need:
1. The ability to solder (I'm sure you already know that by know)
2. A soldering Iron (the smaller the tip, the easier it is to solder small traces!)
3. Solder
4. A PCB or something with a trace
5. Something to scrape the trace with (an exacto knife or screwdriver or something else thin)
6. Something to solder to the trace
(Optional) 7. Helping hands to hold circuit boards
(Optional) 8. Flux
Difficulty:
Very Easy
You'll need:
3. Solder
(Optional) 8. Flux
Difficulty:
Very Easy
STEP 2: Pick and Scrape!
Now pick the area you want to solder to and scrape! You'll notice that you can't solder directly onto the trace. There is a small layer of plastic coating and the polymer solder resist (the green stuff) covering the traces of copper. Our goal here is to remove all the junk so we can get to something that solder will attach to, copper!
STEP 3: Prepare!
Now before you solder anything onto the PCB, you need to prepare your components/wires. You should put a dab of solder on your wire or component using flux and cover the revealed copper trace with solder. If you don't have flux, you can still coat your wire (braided wire usually works best). This will make things much easier.
STEP 4: Solder!
Now go ahead and solder your component/wire to the PCB.
Hint: If your soldering to a very thin trace, you might want to add a dab of hot glue to keep the component in place
(I used a particularly large trace for the example.)
STEP 5: Examples!
The ability to solder to traces can be quite useful in repairs and modifications. In the pictures you can see that I "repaired" a broken trace and added a component to a trace.
I hope you enjoyed my Instructable!
8 Comments
RayM3 9 years ago
thank you.. very helpful!
bwetman 10 years ago
It is really helpful and informative....
thanks
asadeghi 13 years ago
McGrep 13 years ago
nrclark 15 years ago
hg341 15 years ago
F-zero 15 years ago
hg341 15 years ago
