Soldering 101: Lesson 1: Tin the Tip
Intro: Soldering 101: Lesson 1: Tin the Tip
This short and easy instructable shows how (and why!) you tin the tip of the soldering iron.
Never soldered before? Here's where to start.
If you appreciate this instructible, please visit my blog for more ideas:
GoodCleanCrazy
Last week I decided to make a USB powered flashlight.
While I know a lot about computers, I'm pretty much a solder newbie.
This was a problem.
Luckily, though, I work with a formerly-NASA-micro-soldering-certified technician and soldering instructor.
Yesterday, he instructed me as I soldered together my lovely little flashlight.
My newbie perspective is useful as I won't overlook any "obvious" things that more experienced solderers might.
And my knowledgable overseer (Thanks Terry!) taught me the proper methods, so you can do things the right way too.
You will need:
water
solder
A soldering iron
If you can't get a soldering iron with a digital temp readout (and I can't) get a soldering iron with a temperature dial. You'll be glad you did in the long run.
GoodCleanCrazy
This was a problem.
You will need:
water
solder
A soldering iron
STEP 1: Prepare the Iron
Clear your work area (like a desktop).
**If you're reading this instructable, you shouldn't be soldering chips (ICs) yet, but if you WERE to solder ICs, you'd be soldering on an ESD mat.
Plug in the iron and turn it on. Using water, soak the sponge that comes with the iron and squeeze it out a little. This sponge is used to clean solder off the tip of the soldering iron.
Adjust the temperature of the iron to about 750 F(75 on the dial) like so:
STEP 2: Clean the Tip
After a minute or two the iron should be hot enough to steam when touched to the sponge. If not, wait a bit more, or add more water to the sponge if it's too dry.
When the iron is hot, wipe both sides of the soldering tip on the sponge. Your goal is to remove old solder from the tip.
STEP 3: Tin the Tip
When you put a light layer of solder over another piece of metal, it's called "tinning".
Holding the solder in one hand and the iron in the other, briefly touch the solder to both sides of the tip.
STEP 4: Why Tin?
Now that your tip is properly tinned, you can start soldering.
Try to solder immediately after tinning the tip, the sooner the better.
Periodically while you are working (after soldering one or two connections), clean and re-tin the tip.
Tinning improves conductivity and makes soldering easier, as well as quicker, which is a good thing.
Some electronic components are sensitive to heat, and the quicker you can solder them, the less likely they are to be heat damaged.
According to the instructive Terry, properly tinning the iron tip before putting it away will help preserve it.
Comparing our soldering iron (like new), and the iron of the guys down the hall (terrible) this seems to be a good practice to keep.
Happy soldering! -Royal
Like this instructable?
Try Soldering 102: Soldering a Jumper Next!
76 Comments
amplex 10 years ago
Disligaf 5 years ago
IanWizard 10 years ago
Heat conductivity. And I believe it's because it prevents the oxidation, and keeps the tip covered in molten solder.
CharlesM65 8 years ago
Can you solder without tinning? Please reply.
StephenC151 7 years ago
Yes but you're going to get brittle joints if you do. There's also no reason not to do it. It takes about 10 seconds after the pen warms up and doesn't take a lot of solder to do.
chucksdad 6 years ago
pfred1 17 years ago
Jayneedssleep 6 years ago
You posted this comment when i was 6 years old, time has really flown
JSWheeler 6 years ago
Ha!
royalestel 17 years ago
julianj 17 years ago
do you have to tin
CuriousInventor.com 16 years ago
OrusA 7 years ago
Wet spunge is bad choice. I never apply water to the bit. i prefer steel wire mesh. Cleans it much better I find. And preserves the Bit you are using.
I have the same Soldering Iron as you, i bought mine off ebay. Very common on there.
Im not sure if the WES51 is the best brand tho.
Will101 7 years ago
I don't particularly agree with that, but comment back on more reasons why steel mesh is better. I think that not only does the sponge help keep the bit well maintained, but I agree with ScunnerDarkly that companies probably wouldn't include a sponge with every soldering kit if it was worse than steel wire mesh.
ScunnerDarkly 7 years ago
"Wet spunge is bad choice"... Seriously, if that was the case manufacturers of hand-soldering equipment wouldn't supply sponges with soldering stations and iron stands, for that exact purpose. Cleaning a hot soldering bit on wet sponge is quick, effective and non-destructive to the tip's plating. Using steel wool or mesh will reduce the lifespan of the bit as it will wear through the plating at the tip. I know from experience as I've been soldering for nearly forty years.
Yonatan24 8 years ago
Hi, I've added your project to the "Beginners Guide to Soldering" Collection
This is the link If you are interested:
https://www.instructables.com/id/Beginners-Guide-to...
