Soldering Assistant
Intro: Soldering Assistant
NEW!: I have added the adjustable base, so whether you're fine soldering on surface parallel to your bench top, or you prefer to have your board at an angle, this can accommodate your needs! stay tuned, fume extra will be done soon!
The soldering assistant is a project idea I had to have my soldering supplies conveniently in one spot. The Solder spool holder is close to the work area to have a read supply of solder to feed directly from the spool. The soldering assistant also features and adjustable vise to hold your projects securely as you assemble them. Just behind the work area is a parts bin, to put your resistors, capacitors, IC's tweezers or other supplies. Side "fins" make it possible to make custom add-ons that can just snap into place. The only part that isn't printable through a 3d printer is the center threaded rod that moves the base, this is a 1/4" threaded rod that can be purchased at any local hardware store. 2 hex nuts are also required, one that fits into the moving side of the platform, and one on the stationary side. This is an entry for the "Make it real Challenge" contest. If you like the design, please vote, Thanks.
**UPDATE**
The angled platform can be added as an accessory, or use the Soldering assistant without this accessory as shown in the gallery pictures. The adjustable platform pivots on a pin at the front of the base. At the rear of the base is a "C" shaped channel that also pivots, and there is a T-shaped cylinder the rides the inside of this channel. To adjust the height, the user would simply have to tilt the platform forward, lining up the position holes on the C channel, then insert the pin through the C channel and into the T cylinder. There is one on each side of the platform for stability. No more hunching over to work on your PCB's! This allows you to work in a more comfortable position. Special thanks to those who commented and suggested an angled platform!
**UPDATE**
56 Comments
underground carpenter 11 years ago
foxxtrotalpha 7 years ago
I dont mind
foxxtrotalpha 11 years ago
-Franky
wez416 8 years ago
i love this, but i'm having some serious scale issues. Could i print the "SA_w_adjustable_STL.STL" as it is? I am trying to load the individual pieces into cura but like I said I'm not sure how to scale them since they come in either way too big or tiny
this was modeled in an older version of 3ds max, which had some scaling issues. if it comes in too small, scaling up by 10 should do the trick
xxxCHICAGOxxx 10 years ago
im making a portable one with some added features but unfortunately im not making an instructables on it
bricabracwizard 11 years ago
Rockman_64 12 years ago
Rockman_64 11 years ago
foxxtrotalpha 12 years ago
SG1Oniell 12 years ago
Mr. Boo 11 years ago
SIRJAMES09 12 years ago
TY for sharing Sir.
emotec 12 years ago
1. REPLACE THE TREADED ROD WITH AN IRWIN SQUEEZE CLAMP AND ATTACH THE FRONT AND REAR VISE FACES TO IT FOR ONE HAND CLAMPING.
2. MOUNT AN UNUSED 12 VOLT COMPUTER FAN TO DRAW FUMES AWAY FROM WORK AREA TOWARD THE BACK( NOT FULL FUME EXTRACTION, BUT GETS THEM OUT OF YOUR FACE!)
3. ATTACH THE CLAMP TO A BASE WITH AN ARCHED CURVING SLOT AND A HINGE TO ALLOW TILTING TOWARD THE FRONT AND LOCKING IT IN PLACE WITH A BOLT WITH A KNOB AND A T-NUT.
4. ATTACHING SOME LARGE (5 OR 10 MM) LEDS TO STIFF ,HEAVY COPPER WIRES TO CREATE FLEXIBLE LIGHTING FOR TOUGH TO SEE AREAS.
5. USING SAME METHOD FOR ATTACHING A COUPLE OF ALLIGATOR CLIPS(HOMEMADE HELPING HANDS.
6. MAKING AN EXTENSION MOUNTING A HOT AIR GUN WITH CONCENTRATOR TIPS FOR SMD REWORKING AND SOLDER RE FLOW JOBS.
7. MOUNT A GOOD MAGNIFIYER LENS TO A FLEXABLE ARM FOR CLOSE-UP WORK AND READING SMALL PRINT ON COMPONET PARTS , FOLLOWING CURCUIT TRACES ON PRINTED CIRCUIT BOARDS, USING ABOVE MENTIONED LEDS TO BACK LIGHT BOARDS FOR LESS GLARE FROM PADS ON PROJECT BOARDS,
AND FOR TRACEING DOUBLE SIDED PCB'S TO TROUBLESHOOT PROBLEMS.
ANY OR ALL OF THESE MOD'S WILL JUST ENHANCE USABLITY OF YOUR IDEA, AND ADD TO THE LEVEL OF CUSTOMIZATION FOR INDVIDUAL NEEDS. BY THE WAY, CONCEPT IS VERY USER FRIENDLY AND DEFINITLY A MUCH NEEDED PROJECT FOR ANY HOME ELECTRONICS HOBBIST- NICE GOING!!
EMOTEC IN TEXAS
For the input on the case fan, I actually have a design started that is using a 80mm case fan, with a removable cartridge that holds filters specifically made for fume extractors, so the filter can be replaced when needed.
Led suggestion sounds good. Initially thought about mounting the led's to the fume extractor but didn't work out the way I planned.
I love the idea for the hot air. I can't believe I didn't think of that! especially since I just acquired a hot air gun. Ive seen the hot air holders that help keep the nozzle at a set distance from the board. Ill probably make this an addition.
My ultimate goal is to have an all in one type system for the electronic hobbyist. Input from everyone has really helped. Thanks
