Introduction: Soldering Sockets and Header Pins on Straight
Solder sockets and header pins on straight every time. Start by soldering down only two points on a row of header pins or an ic socket, one on each side. Then check the alignment of the pins/socket before soldering the rest of the pins down. This way if things are not aligned you can easily reheat one of your soldering points and straighten out part.
Electronics Tips and Tricks
9 years ago on Introduction
" This way if things are not aligned you can easily reheat one of your soldering points and straighten out part." I've done this a few times and always forget to not hold the header by the pin that is getting re-heated. I got burned by that a few times quite literally! What I do now is plug the headers into a standard arduino and fit the shield board over that. The pins should be perfectly aligned and gravity does a nice job holding the shield board down while you solder.
