Soldering Tips and Tricks
Intro: Soldering Tips and Tricks
tips and tricks to keep your soldering fun and frustration free!
Visit my site at electronic projects
(http://elec.projects.googlepages.com/home)
If you enjoy this instructable please digg it!
STEP 1: Soldering Iron Tip
One day you decide to do some soldering. But to your horror, the soldering iron just wont melt any solder, no matter how long you wait. Chances are you have a dirty soldering iron tip. Lets go offer some solutions
1 get a new tip. depending on what type of soldering iron you have, you can get new tips. There are many different kinds you can get.
2 clean the tip. if you don't already have one, it's a good idea to invest in a tip cleaning sponge. after each soldered connection, clean the tip on the sponge (after getting the sponge damp). You can also buy soldering iron tip cleaners. you put your hot soldering iron tip in them and it will clean the tip, but there will be a lot of smoke.
STEP 2: Step 2
Whew! now your soldering iron tip is clean again. time to start soldering. Oops! Oh no! you made a mistake and have to remove some solder. but how?
1 You can buy solder removing wick. It's a metal wick that when placed over solder and heated with a soldering iron, removes solder.
2 You can buy a solder removing vacuum tube! Yay! after heating the solder to its liquid form, you can use the tube to suck up the solder.
STEP 3: Step 3
Now that the soldering error has been fixed you start soldering again. you solder a connection, but cant tell if its a good one or not. what can you do? Look at the diagram!
STEP 4: Step Four
So now that you know how to make good solder joint connections, you start to solder again. Hmm you think. I wonder if there is more than one type of solder?
1 Yes, there is! There is lead and tin solder, which is 60% tin and 40% lead, and there is lead free solder which is usually tin and silver
Yay! I'm going to use lead free solder, you think to yourself! So you go out and buy some, but for so reason your soldering iron just cant seam to melt the solder. How come?
1 lead free solder requires more heat to melt, so your soldering iron might not be strong enough. 40 watts is enough to melt it, so you can get a 40 watt soldering iron, or higher
2 still not melting? Refer to step one.
STEP 5: The End.
I hope you have enjoyed and found my instructable useful! Happy soldering!
62 Comments
katyR13 6 years ago
DustinH44 7 years ago
ChanW11 7 years ago
it may be counter intuitive, but add some fresh solder to the joint, it will help melting the old solder on the board. It also ease the process of sucking the solder out from the joint with the vacuum pump
handson 16 years ago
Mr. M 16 years ago
brt1 9 years ago
Hey,
I know this is really late but the problem, most likely, originates from the fact that solder is a great conductor. When you soldered the pink wire, there might have been either a direct connection from the black wire to the pink wire (through the solder) or there might have been a small gap in the solder applied to each wire causing the wires to spark. The burning smell probably came from the fact that the sparks were creating short circuits so short in length that the light would just operate until a larger "strand" of electricity jumps between the wires/solder resulting in a more permanent short circuit. If the tip of the wire was burnt, check to make sure that you didn't somehow knock a resistor out of the loop... I, as well, don't have Ny experience concerning these matters...
Mr. M 16 years ago
yoni007 15 years ago
Mr. M 16 years ago
nprince 12 years ago
1: Power does not equal temperature. A 30W iron is not inherantly cooler than a 40W. In the same way as a ferrari and a mini are capable of 30mph and 90mph, the ferari just gets there faster.
2: Lead free solder does NOT require a higher temperature. What is needs is more POWER in order for the iron tip to remain ata stable temp. 80W is the min for good high speed lead free solder (And the right size tip)
3: @Vspec. You are right Lead fumes are not good. However lead can not be vapourised buy any soldering iron, Unless it reaches 1000's of Centigrade because its faulty. Its the Rosin flux that creates the fumes and yes its not good for you.
gojason 10 years ago
Thanks for the clarification. Very well explained about the iron power and temperature.
tunghaichuan 10 years ago
http://www.newark.com/xytronic/460/soldering-tip-cleaner/dp/20J6139?in_merch=true&MER=ACC_N_L5_SolderingStationsAndAccessories_None
It cleans the tip without lowering its temperature.
yes. you are right at that point. but web sponge has its own advantages as well.
mr fat 12 years ago
Vspec 12 years ago
