Introduction: Solid State Air Conditioner With Old Bitcoin Hardware Ver. 2
Version: 2
Solid State Air Conditioner with Old Bitcoin Hardware
Video will show all step needed to complete this project.
Step 1: Parts
Parts from Old Bitcoin Hardware:
2x - Fan
2x - Heatsink
Other Parts:
1x - Huge TEC1-12730 253W Thermoelectric Peltier Cooler
1x - Aluminum Block
1x - 10a DPDT Switch
2x - Veriable Speed Controller
8x - Styrene Sheets 1.0mm Thick
8x - Foam Sheets
Step 2: Glue Styrene and Foam Sheet
YOU NEED TO MAKE 2ND ONE
Glue Styrene and Foam Sheet together cut the the excess foam
Step 3: Measure and Fold
Measure the Heatsink size and cut away the foam, then fold the Styrene sheet
Step 4: Glue Sheets to the Heatsink and Make Fan Box
Glue Sheets to the Heatsink and make Fan box
Glue the fan to the box and seal with Copper Tape
Step 5: Adding Peltier Cooler
Make space on the heatsink and 2-3 layer of copper tapes for the Positive and Negative wire
Solder the Peltier to the Copper Tapes
MAKE SURE YOU ADD THE ALUMINUM BLOCK ON THE PELTIER
