Solid Wooden Sunglasses
Intro: Solid Wooden Sunglasses
Mid last year I made these sunglasses and I thought I would share them here. Check out the video above to see how I made them! Thanks to my beautiful baby sister for kindly modelling these! It's much better than seeing them on me.
STEP 1: The Lenses
First up, we'll need some lenses. I ripped some out a plastic pair of sunglasses I got free!
STEP 2: The Templates
Using the original sunglasses I produced some 1:1 cutting templates. If you are using similar sized lenses you can download the ones I used from my website: http://thiswoodwork.com/making-wooden-sunglasses-summer-woodworking-project/
STEP 3: Attaching the Templates
Next, the templates are stuck to the rough blank with a little wood glue.
STEP 4: Cutting Out the Frames
Using the scrollsaw the frames are cut roughly to shape, If you don't have a scrollsaw you can do this by hand, it's just going to take a while!
STEP 5: Cutting the Frames 2
To cut the opening for the lenses drill through the blank and thread through the blade. Leave the cavity slightly over-sized at this point.
STEP 6: Cutting the Temples
The temples (or arms) are cut out in the same way.
STEP 7: Fitting the Lenses
Align each lens properly and trace around them with a pencil. Sand close to the marked line, leaving a small rim just under 1mm (IMPORTANT) I used a drum sanding attachment at the drill press to do this.
STEP 8: Shaping
The final shape cannot be achieved on the scrollsaw, so using a small handsaw cut away the remaining material and use a hand-file to shape. The original sunglasses serve as a good reference when doing this.
STEP 9: Shaping 2
Using sanding attachments, sand to the final shape. (If you don't have these some careful filing and sandpaper should work.)
STEP 10: Fitting the Lenses 2
Now to cut the rim for the lenses. Using a rotary cutting disk mounted in the drill press for ease, I cut a shallow groove around the edge of the lens cavity, for the lens to slot in to. This will take some care and a bit of trial and error, but should work if you are careful.
STEP 11: The Hinges
Next is the hinges. I could have made some tiny wooden hinges, but it was far easier to cut them off of an old pair of cheap plastic ones!
STEP 12: Fitting the Hinges
To attach the hinges mark the position and cut a small cavity on both the front and temples of the glasses. (I used a small drill bit to do this.)
STEP 13: Gluing the Hinges
The hinges were glued into the cavities with some quick-set epoxy.
STEP 14: Applying the Finish
Finally a finish can be applied to the glasses, before the lenses are pressed into place. For a finish I used mineral oil just to be safe, but I am sure that some spray lacquer would be fine too!
32 Comments
Van57 4 years ago
Duplicate the shape from other sunglasses.
Thank you.
farraha 8 years ago
Great
jrow00 8 years ago
what kind of wood did you use and where do you recommend we get it?
Marker1024 9 years ago
Well done! You should treat yourself and those frames to a nice pare of polarized lenses! Its a disgrace to use the cheep ones in when you've crafted the rest of the sunglass so nicely! Great cheep project though.
BenMercier 8 years ago
buck2217 8 years ago
They are great but knowing me I would either leave them in the pub or sit on them -- cue heart broken!!
kdorais 8 years ago
Definitely gonna try to make these this summer, but with actual lenses since I have terrible vision :P These are so cool!
sabladask 9 years ago
HarshanaS 9 years ago
Could you do these with regular glasses?
Spokehedz 9 years ago
Yes. Same principal, just be far more careful with the real lenses.
mjackson-1 9 years ago
Just don't forget that prescription lenses factor in pupilary distance and have a focal point... there's a lot more precision required than for non-corrective lenses.
Thanks
Containerschiff 9 years ago
Wow they look awesome! You've got some nice skills! You make the sunglasses yourself while others buy them for a lot of mony at a (desing) shop!!
keep your work up - i'm looking forward to seeing new projects
onemoroni1 9 years ago
Very cool. Nothing like hand crafted.
acaig 9 years ago
I was always annoyed at school the boys got to do woodwork and girls had to do home economics it was so unfair from a very early age I used to stare longingly in to the workshop classrooms and my brothers told me id do them for at 11 lying watsits
dirizary 9 years ago
Fantastic.
fixfireleo 9 years ago
wow, beautiful work by a beautiful artist!
Dandie 9 years ago
This is great, admirable.Very nice work, congratulations!!
kodiwoedee 9 years ago
CK101 9 years ago
