Sound Reactive WS2812 LEDs With Arduino and Sound Sensor
Introduction: Sound Reactive WS2812 LEDs With Arduino and Sound Sensor
Hello together,
i made a sound reactive chain of WS2812 lights with table tennis balls and i control it with a sound sensor and an arduino. This is a easy project which beginners can do.
Step 1: Circuit
I connected the WS2812 LEDs like in the picture. Dont forget that you cant supply too much LEDs with the arduino. Use a separate power supply therefore. I used a 470 Ohm resistor in series for the data line, and a 1000uF capacitor (at least 5V) in parallel with the supply.
I got the sound sensor here:
Sound sensor
But you can also get it anywhere else. You also can get the WS2811 LEDs and the other stuff at many shops.
Step 2: Programming
To control the LEDs you need the Adafruit library which you can get here:
https://github.com/adafruit/Adafruit_NeoPixel
Because the sound sensor only gave me a high or a low level signal, I take 100 analogValues from this sensor and count how often they are high. Through this relation I can control how many LEDs shall be turned on.
LED Contest 2017
LED Contest 2017
Be the First to Share
    • Hand Tools Only Challenge
    • Modify It Speed Challenge
    • Remix Contest
      Remix Contest
    8 Discussions
    MatteoM65
    MatteoM65
    1 year ago
    Hi there, I have got this to work with my string of LEDs, but only for the first 25 out of a possible 96 LEDs. I have tested the string with different code and they all work. Is there something I can change in the code?
    Grasscutter_
    Grasscutter_
    Reply 1 year ago
    Same problem here. I tried to figure out how the code actually works in order to adapt it to my led strip length. Guess it is so easy that I overlooked it - or I'm just incredibly stupid. SEND HELP PLS
    LordVallejo
    LordVallejo
    1 year ago
    Hey brother, thank you so much for your time and code, it works pretty good, this is what I was looking for.
    titanx980ti
    titanx980ti
    Question 1 year ago on Step 2
    i do not have the mic sensor , is there a way of using headphone jack as an input ?
    Swansong
    Swansong
    2 years ago
    That looks neat, it would be fun for party lighting :)
    tytower
    tytower
    2 years ago
    Just posting the ".ino" file is the way to go.
    electronstogo
    electronstogo
    Reply 2 years ago
    Oh, sorry. Next time I will do that.
