'Sound Graffiti'
Intro: 'Sound Graffiti'
This is a simple electronic gadget you can build for yourself using old electronics and cheap kits. Connect the components, protect them with polyurethane foam and install them in the street. Record a message and let others record their own message.
//// Vox Populi is an open source project based in DIY interaction designs to fight advertisement and corporate branding in our streets.////
STEP 1: Connect the Components
This is what you need:
ELECTRONICS
_Voice synthesizer type Cebek ref. C9701 or similar. (Basically a 20seg voice rec+play)
_Speaker (as big as you want, consider 4 cm /1.6inch diameter minimum)
_Switch
_Infrared sensor (I used CROW ref. SPR-100, but any alarm infrared sensor should work also tiny like cebek ref.7288)
_5V Relay
_Batteries (depending of synthesizer and infrared)
PROTECTION
_Polyurethane foam, sold in spray avaliable in any drugsore
_Half plastic bottle
TOOLS:
_soldering iron
_Silicone mould (optional)
_Cutter
_Gluegun
ELECTRONICS
_Switch
_5V Relay
PROTECTION
TOOLS:
_soldering iron
_Cutter
_Gluegun
STEP 2: Change Speaker and Rec Button
Usually voice synthesizer are provided with tiny speakers, change the original one and connect a bigger one to obtain louder sound. (I used one as big as my bottle screw top as they have to fit together)
Change also the rec button for a lamp switch to make an easier interaction.
The switch is going to work better if you stick it to a piece of wood or plastic as a lever.
At the end, secure the connections with the gluegun to make sure it's going to work.
STEP 3: Change Play Button
Change now the play button for the infrared sensor. That means that the gadget is going to play the recorded message when pedestians walk close to it. That makes a much more interesting interaction that through buttons.
Follow the connections of the original play button and exchange them for the infrared. Remember to use the Relay.
STEP 4: Protect
Before putting it al into foam, protect the sensible/mechanic parts to avoid foam disables them. Protect the speaker, microphone, sensor and switch. (follow the sketch)
STEP 5: It's Foam Time
Now that the electronics are done make sure they work as planned.
If everything it's ok, then find a silicone mould (any pastry-mould should work) or any other PP / PE packaging (foam is not going to stick to it). You can also work without mould, by putting trhe foam directly on the electronics.
*Foam is not only going to keep things together but to protect them from weather
Wait util the foam is completely dry (also inside) - usually takes from 6 to 12 hours (see foam spray instructions)
STEP 6: Battery Location
When the foam is completely dry it's easy to shape simply by cutting it with a blade (cutter).
STEP 7: It's Done!
Now do a hundred of them and spread them away!
(stick them to the walls with some more foam)
*depending on the batteries should work for a week at least
55 Comments
rah187 7 years ago
Intresting idea! I have a feeling you could turn a few heads with this project (and freak a few people out...)! It's a shame that I don't have a recording module and an infrared sensor on hand, otherwise I could throw this one together in a few minutes (excluding the foam, of course; that could take an entire day).
Wasagi 13 years ago
artonline 13 years ago
Art gallery
Sputny 14 years ago
Younggun 14 years ago
abadfart 14 years ago
skatelong 14 years ago
vandal1138 14 years ago
eneergcam 14 years ago
BladedZealot 14 years ago
carrotman42 14 years ago
psyteknology 14 years ago
pdub77 14 years ago
jmeister15 14 years ago
radiobath 14 years ago
phoenix124 14 years ago
mgordi 14 years ago
jeff-o 14 years ago
mgordi 14 years ago
jeff-o 14 years ago
