Introduction: Spanish Omelet - Tortilla Española
This Spanish dish is made from eggs and potatoes. Some add onion or some more ingredients such as chorizo, tuna or vegetables. You can enjoy it hot or cold as a starter, main dish or cut into bite size pieces and served as tapas or at a picnic.
It is a pretty simple recipe and when served with bread and salad it is a great option for lunch or dinner!
In Spanish recipes the potatoes are cooked right in the pan, but to save some time I parboil them first.
Enjoy our easy recipes!
Step 1: Ingredients:
600g Potatoes
4 Large Eggs
1 Medium Onion
Pinch of Salt to taste
5 Table Spoons Olive Oil
Optional:
A Few Sprigs of Fresh Flat Leaf Parsley
Makes: 2 portions
Time: Preparation 10 mins, Cooking 35 mins
Step 2: Method:
Take a medium sauce pan, add water, salt and bring it to the boil.
Wash, peel and cut the potatoes (cut into slices or dice). Add to the water and parboil them for 5-7 minutes.
Meanwhile:
Peel and dice the onion. Heat up 2 table spoons of olive oil in a frying pan (bottom of the pan should be about 20cm in diameter) and add the onion. Sauté for about 5 minutes.
Now drain the potatoes (make sure you don’t overcook them – they should be cooked partially only to speed up the process) and add them to the pan. Cook for about 10 minutes, mixing (or tossing) occasionally.
Meanwhile:
Break the eggs into a bowl and whisk them with a fork. Add a pinch of salt and finely chopped parsley.
Once the potatoes are cooked, add some more oil, pour over the beaten eggs and reduce the heat to the lowest temperature.
Cook slowly until the omelette is set. Now it is time to turn it over. For this, use a plate (cover the pan with the plate, holding both turn the pan over. Transfer the omelette back onto the pan) add some more olive oil and cook for a further 3-5 minutes.
Serve with a slice of bread and salad.
Happy Cooking with Happy Foods tube!
