Firestarter & Tinder Case V2
Intro: Firestarter & Tinder Case V2
Some of you might recall the flint and sparkwheel firelighter that I made awhile ago. It's very handy for getting char cloth lit or even gas stoves or blowtorches but there was no-where to store tinder. After a couple of good ideas supplied by the community I decided to revisit and include a container to store tinder.
As you can see from the images, the main body is quite large. This is where the tinder is kept! The container is held into place with a screw that also serves as a stopper for the spring and flint.
The spark generated is larger than a normal lighter. This is because there is more force from the spring onto the flint. It will use the flint up quicker but you can just replace once it has been depleted. I've also experimented with a few different types of tinder which you can see in the video and in step 12. All of these will fit into the container and the sparkwheel does an excellent job in igniting them.
If you wanted to you could add some other survival tools inside the storage area instead like hook and sinker, floss (great for fishing line, binding) etc.
This is also a great use for old, disposable lighters as well.
STEP 1: Parts and Tools
Parts:
1. Old lighter. Try and make it the larger kind as the sparkwheel is larger and so is the flint.
2. 2 x 15mm brass caps
3. 12.7mm copper tube. You can find this in the plumbing section at your hardware store. This tube will fit inside the 15mm caps
4. Small brass or copper tube. The size will depend on the dimensions of the spring in the lighter. I pulled apart the lighter and took this to the hobby shop to find the right sized tube
5. Brass or copper strip. Hobby shop. Don't get it too thick or you will never be able to bend it. Same goes with too thin!
6. Screw. The screw needs to be slightly smaller than the small brass tube.
7. Copper wire. Hobby shop. This is used to make the ring
8. Cloth. Best cloth to use is cotton cloth.
Tools:
1. Pliers. Needle nose, small and large ones. Just use whatever you have
2. Blow torch. I used a mini one and a larger one to solder the larger copper piping together.
3. Solder
4. Dremel (always comes in handy)
5. Grinder
6. Files
7. Drill
8. Metal Polish
STEP 2: Pull the Lighter Apart.
Steps:
1. First remove the metal guard.
2. Next, carefully remove the sparkwheel making sure that the spring doesn't fly off.
3. Put aside the sparkwheel, flint and spring
STEP 3: Cut the Small Tube
Steps:
1. Put the spring next to the tube. You want about 10-15mm mm of spring sticking out the top. The more pressure you have the spring under, the more spark you'll get. However, it will mean that putting the screw in place to hold the spring will mean it is under pressure and could make the job hard.
2. Cut the tube. I used a dremel with a cutting wheel
3. File the end and make it smooth. Also, de-burr the inside. You can see in the last image that once the flint is in the tube there is about 10-12mm of the spring sticking out.
STEP 4: Make the Bracket - Bending
This can be a little tricky. You want to make the bracket so the spark wheel fits correctly.
Steps:
1. Make a 90 degree bend in the copper strip.
2. Next, grab the spark wheel and use this to work out where to make the next bend. You want to have it so when bent into a "U" shape, the 2 pins on the spark wheel rest on the copper strip.
3. Cut and trim the bracket and lastly, round off the edges. I used a sanding drum on my dremel but you could also use a file.
4. Lastly, you need to drill a hole into the bottom of the bracket. Mark the centre and make a hole. The hole should be the same size as the small brass tube. You want this section to be a tight fit so start with a drill bit slightly smaller than the tube and work your way up.
You now have all of the parts for the sparkwheel and flint section, you now need to build the storage section
STEP 5: Cutting the Copper Tube for the Container
Steps:
1. Grab the small copper tube and place it against the large copper tube. You need to cut the large copper tube roughly the same size as the small one.
2. Use a grinder to cut the tube
3. File down the ends and de-burr
STEP 6: Soldering and Drilling the Cap
You need to solder one of the 15mm caps onto the copper tube. This will make your storage container
Steps:
1. Once you have cut the large copper tube to size, add a little flux to one edge and push on a 15mm cap
2. With a blow torch, heat the tube and cap and once hot enough add some solder around the edge.
3. Once cooled, mark out the centre of the cap (or as close as possible) and with a drill make a hole. The hole needs to be a little larger than the small brass tube.
4. Lastly give it a clean with some metal polish
STEP 7: Adding the Sparkwheel Bracket to the Cap
Steps:
1. Find the centre of the cap and drill a hole into it. The hole needs to be the same size as the small brass tube. It doesn't have to be too tight a fit but you don't want much slop. Put it to one side for the second
2. Next, grab the sparkwheel bracket and place the smaller brass tube into it. You only want the smallest amount of tube showing out the other side (like in the images below)
3. Add some flux to the top of the cap and then push the small brass tube through the hole so it is touching the bracket.
4. Grab the blow torch, heat-up the metal and add some solder to the bracket and cap.
5. Push the container onto the cap and make sure that the smaller tube lines-up with the hole in the cap. If it doesn't, then use something to jimmy the small tube until it lines-up with the hole.
6. Lastly give it a polish
STEP 8: Adding the Sparkwheel to the Bracket
Steps:
1. Use the spark wheel to determine where you need to add the first hole. Once the first hole is drilled you can use this to determine where the second needs to go. If the holes aren't lined-up correctly, the wheel will be crocked and you may have to redo which would be a pain.
2. Carefully drill the first hole. The drill piece you use should be the same size as the pins on the spark wheel. The hole can be off-centre so if it isn't in the middle don't fret.
3. Drill the other hole and remove any burrs.
4. Here's what you need to do to get the wheel into the bracket: - Put the wheel on top of the arms of the bracket. - Push down on the wheel and try and push it into the bracket. - once in the bracket, line-up the pins on the wheel to the holes in the bracket. If one of the sides of the bracket is bent out, use some pliers or a vice to straighten. You may have to bend one of the brackets slightly outwards to get the wheel in. If you do, use a pair of pliers to push the arm back into place once the wheel is located correctly.
STEP 9: Adding the Screw and Putting It All Together
As mentioned previously, you need to add a screw into the end of the small copper tube. The screw also holds the
Parts:
1. Push the screw into the top and then with a phillips head, start to turn the screw into the copper. I just screwed the screw in with force to make the thread.
2. Take your time and if it feels like it's getting stuck, un-screw and re-screw until it's got a good foothold.
3. I left the tinder container in place whist I forced the screw into place. It gives you something to hold whist you are doing this.
4. Once the screw is in place and is holding everything together, you then can undo and place the flint and spring into the small tube. Put the container into place and put the screw into place. Be careful as the spring will be under load and might "pop" out if you are not careful.
5. Test the sparkwheel and ensure the flint is sparking.
6. Lastly give the whole thing a good polish
STEP 10: Adding the Ring
Steps:
1. First thing to do is to bend the copper wire into a ring. I used a pair of round pliers to do this but you could just as easily bend the wire around a pencil or something else round.
2. Cut the ring off once you have a good, round shape.
3. Next, add some flux to the join in the ring and align this to the top of the screws head. I had a 3rd arm hold this in place
4. Lastly, with a mini blow torch, heat-up and add a good quantity of solder. You will be using the ring to loosen and tighten so it needs to be secured well.
STEP 11: How to Use
Hopefully “how to use” is self-explanatory but if it isn’t - keep on reading
Steps:
1. To open the container first you undo the screw by turning the ring
2. Once you have undone the screw the spring will pop out. Put this to one side and make sure you don’t lose the flint as well.
3. The container fits into the top brass cap so just pull the bottom cap to remove it
4. I keep 4 x cotton bud heads in one and some wax and lint in the other. As I’ve already mentioned though, you could keep whatever you like inside.
STEP 12: What Tinder to Use
Char Cloth
You can make some char cloth as tinder and this lights instantly when hit with the spark. If you want to use this then check out this ible' - step 7. The downfall of charcloth is it doesn't flame, it smolders so it can be hard to ignite what your trying to set on fire. Also, it's fragile so storing it in the container can easily tear and wreck it.
As the spark produced is quite large, you should be able to light cloth directly. Just make sure that the cloth is cotton and a little frayed. I have done this plenty of times
Cotton Buds and Wax
This is what I put into my one. The great thing about them is they catch on fire easily and the plastic then catches alight and act like a match. I also add a little wax to the bottom of the cotton bud so they burn a little longer
Link and Wax
This burns very well and is easy to ignite Check out this ible' to see how to make it
Check out the Youtube clip in the intro to see these tinder's ignite
STEP 13: What Next
Maybe there is a better way to hold the container in place where you don't have to un-screw the flint/spring section? Actually I'm sure there is and if you know what it is, please let me know in the comments.
What about tinder? I'm sure that there are a tonne of different tinder that you could use.
I think I could also just turn these into lighters with a wick etc. Might explore that in a later ible'
In the end I'm really happy with the finish. Don't forget to post an image in the comments if you do make one.
Any questions, please let me know.
27 Comments
TheAppleSauceMan 7 years ago
You see, it's getting much rarer these days, but it's every so often that an Instructable comes along that not only expanded on a previously brilliant idea, but does it in a new, exciting and aesthetically pleasing way.
This is one of them.
The amazing functionality, well executed and implemented idea through to design, and the strange but pleasing blending of dual opposing aesthetics; both hard, cold and metalic, and of organic, warm and natural - respectively, in the material & construction and in the shape & tones - all join to make a very nice, functional but aesthetically pleasing item, that i'm sure will not only be treasured, but also inspire you to continue down it's fundamental idea path - to lead you on to pursue the next generation, that will be more so than the last.
- TASM
lonesoulsurfer 7 years ago
Thanks for the beautiful words! Always puts a smile on my face when I get such awesome feedback.
The Crystal Railgun 7 years ago
No problem :)
However, it takes a lot of tools and other not easily found stuff, so I suggest, as a V3, a modification to the lighter case itself so you don't have to remove the striker wheel and add copper pipe; the empty butane cartridge would be the tinder holder. Don't forget to credit me if you do make it :P
I agree entirely. This is a useful, comprehensive Instructable. The only problem is it's not really *trash* to treasure, but it's treasure for campers... :P Good job; keep at it! :D
~ TCR
I the trash comes from the disposable lighter. You can't top these back up again with gas so in most cases they are just thrown away
jermncoco 7 years ago
Dr. Gonville Farnsworth 7 years ago
While the intended use is perfect, I am intrigued by your idea of making these into lighters. I know the old Zippo lighters use a simple cotton fibre wick to hold Naptha (Ronsonol) fuel and work rather well. I would think a similar approach would work. Have you ever looked at the old Alfred Dunhill gas lighters? There may be an idea or two there a bloke could copy as well.
My idea was to make something like a zippo lighter. I reckon you could add a wick easily into the cap and move the sparkwheel over. The only probelm would be you need to enclose the wick so the fuel doesn't dry out. I haven't worked out that part yet. Maybe another cap on top or a small call just around the wick...
mid_life_crisis 7 years ago
A Zippo pipe lighter with no fuel and the wick and batting removed would make a marvelous fire starter kit. There's a cover to protect the striker mechanism and the hollow body is the perfect place to put tinder and an extra flint. You could even keep the spare flint under the cover. Tuck a small bit of tinder into the chimney and it should go right up. No worrying about fuel drying out.
I like your 'ible, but you've now given me an idea I think is even cooler, not to mention brain dead simple to execute.
ZaneEricB 7 years ago
Amazing!
- a few suggestions....
1) remove the loop from the sparker,maybe shorten the spring/tube..this way you don't have to take the screw out and possible lose your flint and spring
2) solder the bottom on the tube and include an eye hook soldered through the bottom so you can affix your keys
3) thread the copper top and tube so that you can screw the sparker top onto the tube...
what do you think?
Love all of your ideas. The hardest part to find though is a 15mm threaded cap. If I could get these with the right shape (you can only get them as hex nuts and they are bulky) then having the container section screw in would be ideal. I could round the hex nut but that would take a whole bunch of time to do.
Thanks for the suggestions.
GraphixS6 7 years ago
Maybe an idea for v3: Have a screw on cap over the flint so even if submerged in water you can use it without waiting for it to dry?
I did try and think of a way to add a cap but couldn't find anything suitable enough. Especially if I wanted to keep it as small as it is.
ludionis 7 years ago
1) Make the spring tube longer or cut the spring shorter, and store extra flints inside the spring tube itself, stack so they replace themselves when used up.
2) Instead of glueing a homemade loop to your screw, get a small eye bolt for 1 less point of glueing/breakage.
I really like this idea! Could even go with 3/4 inch copper pipe and caps for more storage and only slightly increase the size of the overall tube. Good job!
YES! great ideas. Love the first one especially.
MK1Jack 7 years ago
You could I guess do that but pushing the spring in and then the pin might be a little difficult.
MK1Jack 7 years ago
yrralguthrie 7 years ago
Good construction and methodology, but why did you remove the striker mechanism from the lighter? And why rely on tinder when there is propane in the lighter if you leave it together?
