Spectacle Phone Stand !
75
Introduction: Spectacle Phone Stand !
So don’t you just hate carrying around your spectacle box everywhere you go but use it only few times so you are just carrying a dead weight or do you have bunch of spectacle boxes laying around and don’t know what to do with them ?
Well, NOT ANYMORE !!!
With this project we are going to turn that boring waste of space into a phone stand so you won’t feel that you are carrying that thing for nothing ! And you will give those poor boxes a new meaning of life !
So let’s go !!!
1- Spectacle box
2- Silicon gun
3- A marker
4- A rubber like material (Something that is flexible and can produce friction)
5- Cutter
6- A phone (
Step 1: So Basically...
As you can see in the photo, I have already made a little sum up for how this project will go...
With this we will have a general idea about what will we be doing so let’s not waste anymore time and let’s start already !
Step 2: Choose a Box !
Let’s start with choosing a spectacle box,
The chosen spectacle box should be spring based since we will be needing a sturdy platform !
For my case I went with this box !
Step 3: Testing Testing...
Try placing your phone in the desired position and angle that you are the most comfortable in !
Step 4: Get Your Markers !
After you are satisfied with your phones position, use your marker and mark the spots that your phone contacts with the box !
Step 5: Like So
Since my chosen spectacle box looks like a rorschach I had to circle the spots just like in one of those UFO sighting videos hahaha !
Well jokes aside,
After you have marked all the contact spots we are ready to move on !
Step 6: Cutting Time !
Take your chosen rubber like object then cut it just in a way that the pieces will support your phones corners (contact points) just like in the pictures !
After you have finished cutting them, it’s time to use your glue gun to “seal the deal” literally !
Glue your pieces in a way that only 3/4th of the area is glued so that the 1/4 part will be sticking out !
Step 7: Ta-Dahhhh
After you have done, it should look like something like this !
As we can see, those sticking part are supporting the phones corners for extra security and sturdiness so that you can use it with peace of mind !
Thank you and enjoy !
Hope you liked the project !
Step 8: B-b-Bonus Projecttt ?!!!
Unlike the previous project that is changing the function this one focuses on the enhancing functionality part !
The point of this one is to ensure your glasses security by holding it on one place even if you shake it and drop it !
Yes the case protects the glass from the outside but since we are using different boxes here it might not be as safe as we think it is ! (At least psychologically)
Enjoy !
Materials needed :
A spectacle box
A styrofoam
A ruler
Your Glases (duh)
Cutter
Silicon gun
A marker
Be the First to Share
    • Metal Contest
      Metal Contest
    • Plywood Contest
      Plywood Contest
    • Crayons Challenge
      Crayons Challenge
