Speech Recognition With Arduino
258,713
297
120
Introduction: Speech Recognition With Arduino
In this project I use BitVoicer’s speech recognition features (http://www.bitsophia.com/BitVoicer.aspx), one Arduino board and one electret microphone (https://www.sparkfun.com/products/9964) to control a few LEDs.
This project is similar to the one in my first post (https://www.instructables.com/id/Speech-Recognition-with-BitVoicer-and-Arduino/), but now I use audio streaming to send audio to BitVoicer.
The fritzing schematic I added to this instructable shows how I wired my Arduino board.
I’m also adding a few pictures and a YouTube video of the project running.
Unfortunately, the sketch I wrote for my first post is no longer supported by the new version of BitVoicer. Here is the new sketch:
#include <BitVoicer11.h>
//Instantiates the BitVoicerSerial class
BitVoicerSerial bvSerial = BitVoicerSerial();
//Stores true if the Audio Streaming Calibration tool
//is running
boolean sampleTest = false;
//Stores the data type retrieved by getData()
byte dataType = 0;
//Sets up the pins and default variables
int pinR = 3;
int pinY = 5;
int pinG = 6;
int lightLevel = 0;
void setup()
  //Sets the analog reference to external (AREF pin)
  //WARNING!!! If anything is conected to the AREF pin,
  //this function MUST be called first. Otherwise, it will
  //damage the board.
  bvSerial.setAnalogReference(BV_EXTERNAL);
  //Sets up the microcontroller to perform faster analog reads
  //on the specified pin
  bvSerial.setAudioInput(0);
  //Starts serial communication at 115200 bps
  Serial.begin(115200);
  //Sets up the pinModes
  pinMode(pinR, OUTPUT);
  pinMode(pinY, OUTPUT);
  pinMode(pinG, OUTPUT);
void loop()
  //Captures audio and sends it to BitVoicer if the Audio
  //Streaming Calibration Tool is running
  if (sampleTest == true)
    //The value passed to the function is the time
    //(in microseconds) that the function has to wait before
    //performing the reading. It is used to achieve about
    //8000 readings per second.
    bvSerial.processAudio(46);
  //Captures audio and sends it to BitVoicer if the Speech
  //Recognition Engine is running
  if (bvSerial.engineRunning)
//This function runs every time serial data is available
//in the serial buffer after a loop
void serialEvent()
  //Reads the serial buffer and stores the received data type
  dataType = bvSerial.getData();
  //Changes the value of sampleTest if the received data was
  //the start/stop sampling command
  if (dataType == BV_COMMAND)
      sampleTest = bvSerial.cmdData;
  //Signals BitVoicer's Speech Recognition Engine to start
  //listening to audio streams after the engineRunning status
  //was received
  if (dataType == BV_STATUS && bvSerial.engineRunning == true)
    bvSerial.startStopListening();
  //Checks if the data type is the same as the one in the
  //Voice Schema
  if (dataType == BV_STR)
    setLEDs();
//Performs the LED changes according to the value in
//bvSerial.strData
void setLEDs()
  if (bvSerial.strData == "wake")
    digitalWrite(pinR, LOW);
    digitalWrite(pinY, LOW);
    digitalWrite(pinG, LOW);
    digitalWrite(pinR, HIGH);
    digitalWrite(pinY, HIGH);
    digitalWrite(pinG, HIGH);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "sleep")
    delay(200);
    delay(200);
    delay(200);
    lightLevel = 0;
  else if (bvSerial.strData == "RH")
    lightLevel = 255;
  else if (bvSerial.strData == "RL")
    lightLevel = 0;
  else if (bvSerial.strData == "YH")
    lightLevel = 255;
  else if (bvSerial.strData == "YL")
    lightLevel = 0;
  else if (bvSerial.strData == "GH")
    lightLevel = 255;
  else if (bvSerial.strData == "GL")
    lightLevel = 0;
  else if (bvSerial.strData == "ALLON")
    lightLevel = 255;
  else if (bvSerial.strData == "ALLOFF")
    lightLevel = 0;
  else if (bvSerial.strData == "brighter")
    if (lightLevel < 255)
      lightLevel += 85;
      analogWrite(pinR, lightLevel);
      analogWrite(pinY, lightLevel);
      analogWrite(pinG, lightLevel);
  else if (bvSerial.strData == "darker")
    if (lightLevel > 0)
      lightLevel -= 85;
  else
    bvSerial.sendToBV("ERROR:" + bvSerial.strData);
The BitVoicer Voice Schema I used can be downloaded from: http://www.justbuss.xpg.com.br/BitVoicerTest2.zip (you need to have BitVoicer installed to be able open it).
Now I want to control a few things (lights and celling fan) at home. Suggestions are very welcome.
Be the First to Share
    • Battery Powered Contest
    • Plywood Challenge
      Plywood Challenge
    • Plastic Contest
      Plastic Contest
    120 Discussions
    yashwanthbalan75
    yashwanthbalan75
    3 months ago
    compilation terminated.
    exit status 1
    BitVoicer11.h: No such file or directory
    im getting this error
    kindly help me to correct this
    I need to complete this project
    sademre
    sademre
    Question 2 years ago
    please sent your preferences for communication
    sahilsankhyan
    sahilsankhyan
    Question 2 years ago on Introduction
    sir have to print A to Z alphabets on lcd by peaking through arduino can u help me in coding?
    sushmitah4
    sushmitah4
    Can Bitvoicer be used with an ATTiny85 to program the commands and remove the dependency of having it work with the laptop?
    alannap2
    alannap2
    Answer 2 years ago
    I agree that's where the real fun starts everyone is doing the same stuff
    alannap2
    alannap2
    Let's see a voice water gun keep seeing all the same stuff
    HeathD4
    HeathD4
    4 years ago
    I have been getting an error in the code...compilation terminated. exit status 1 Error compiling for board Arduino/Genuino Uno
    both the arduino uno and correct com port are chosen
    ArsamA1
    ArsamA1
    Reply 3 years ago
    I had same problem. I solved it by including library used in the code. Hope it works for u
    TommieP1
    TommieP1
    Reply 2 years ago
    Go to your installation folder of BitVoice, copy the contents of 'library', paste them into 'libraries' in the arduino installation folder
    Uddipta206UdDReX
    Uddipta206UdDReX
    Reply 3 years ago
    Try googling ur error or post in arduino forum.
    choboi
    choboi
    3 years ago
    I need help with the communication settings for my microphone. I am using the max4466 electret microphone but from the bitvoicerserver manual it says the serial number must be 20 characters. How did you guys find the serial number for your microphone?
    TristanS50
    TristanS50
    3 years ago
    Is there a way to edit what the arduino accepts as audio inputs?
    SANTAMANYU GUJARI
    SANTAMANYU GUJARI
    3 years ago
    You can control home appliance with a relay module.
    I have made an instructable tutorial on Home Automation, just check out if you need help .
    Harold Tracey
    Harold Tracey
    Reply 3 years ago
    Santamanyu
    I have found a comment you made in 2013 - about a 100 years ago, or it seems that long. I need exactly what you wrote about. Schematics and software for a miniature device that can hear an audio codeword amongst daily normal noise and when it hears that closes a relay. Any contribution available from you as to how and what can do this?
    Harold Tracey - dvrdigital@gmail.com
    Aditya Tripathi
    Aditya Tripathi
    3 years ago
    Can this thing be wireless. I mean connected to the cloud and not to the computer
    Uddipta206UdDReX
    Uddipta206UdDReX
    Reply 3 years ago
    Surely you can. Nothing is impossible. but you will need more modules to fill the gap like wifi shield, etc as per ur requirement. But if you want to connect to the cloud also you will need to process the voice somewhere to make it detect as a command. So think about it
    suryak53
    suryak53
    3 years ago
    Can i use bitvoicer software for speech recognition without connecting it to pc?
    Uddipta206UdDReX
    Uddipta206UdDReX
    Reply 3 years ago
    Then you would need to use raspberry pi instead of a pc. Arduino itself isnt capable of doing anykind of voice or image processing itself.
    kypperb
    kypperb
    3 years ago
    Hello, where can I get the arduino library
    alexa356
    alexa356
    3 years ago
    hello there how you doing ? it is nice what you have posted. I was working on speech recognition elevator using arduino and speech recognition module v3, how can i interface these things ? I have only two weeks for defence so pleas help me ?
