Speed Up Ur Computer Without Buying Anything
Intro: Speed Up Ur Computer Without Buying Anything
This instructable teaches you how to make your computer perform better for free
i know the pics are weird just click and scroll down
STEP 1: Open Note Pad
Start up notepad... Put in the following
mystring=(80000000)
thats an 8 with seven 0s
mystring=(80000000)
STEP 2: Saving
save as:
ram.vbe
vbe isnt the file format just save it as a txt file
Make sure it is on ur desktop
ram.vbe
STEP 3: Just Double Click
Just double click it and it will clean up ur ram and your computer will run faster.
I garuntee that this will not harm ur computer
Just try it u wont regret it
41 Comments
noahw 16 years ago
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
https://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
Xellers 16 years ago
LynnA4 8 years ago
It helped a bit and real easy to do
SohamS1 8 years ago
This Instructable DOES NOT works for 2 reasons -
1) Anything saved as txt file would just be opened in notepad and have no effect.
2) You shouldn't anyways 'clear' RAM as sometimes it makes PC even slower (cause SOME apps(not all) stop even system services to clear RAM, which is harmful and sometimes you need to restart PC).
kenzie droege 8 years ago
its not working now its just slower than it originally was.
AnarchistAsian 15 years ago
joehadac 15 years ago
thewindowshacker99 8 years ago
Physical memory is storage space that the CPU can quickly access. This program fills up the Physical memory, And the CPU gunks up. When the space is freed by the process being deleted, There is more avalible RAM for a couple of seconds. Then the ram is taken by other programs that need it.
Other kinds of memory include- Hard disk, CD-ROM, CD, DVD, And USB devices. There is no speed boost you gain by deleting off these mediums. This program can be harmful to the computer by overworking the Physical Memory, Shortning the life of it.
J_SCAP 15 years ago
Cat Dance 11 years ago
harley_rly 13 years ago
Trelligan 14 years ago
The program declares a large string. This takes a lot of RAM, forcing Windows to make space by writing data from RAM to the hard drive storage area.
The program then terminates, freeing the RAM.
Your computer now has a large contiguous space for computing, which makes it run faster - for a while.
This technique is most useful when you use the computer for long periods of time without rebooting, when RAM fills with many separate pieces of data that aren't being used but just taking up space.
Unless you make major errors with this program (unlikely, it's so simple) there can be no downside to using it; you just might not notice much difference depending on your setup and usage pattern.
The one real problem that could happen is that your computer doesn't have enough unlocked memory available to do this housecleaning; in which case the program will exit with a possible error message - and you'll be no worse off.
MrCantThinkOfAName 14 years ago
minimustangs 14 years ago
Brother156 14 years ago
peonatre 15 years ago
J_SCAP 15 years ago
Matt_Hacks6 15 years ago
magicentral 15 years ago
