Speedlite Isopropyl 2000 Diffusor
Intro: Speedlite Isopropyl 2000 Diffusor
How to make the Isopropyl 2000 Flash Diffusor at Home.
This tutorial will help you make a diffuser for your flash unit. I am not responsible for any damage that may occur as a result of the use or misuse of this tutorial or the diffuser, or for your friends laughing and pointing their finger at the diffuser when you are using it.
Have fun, and happy shooting!
STEP 1: You'll Need...
You'll need: Ruler, Scissors, 2 wide velcro, Tiny hole punch, Sharpie, Paper Clip, Isopropyl Alcohol bottle. For attaching the velcro, six poly-resin snaps or a needle and thread.
STEP 2: Step 2
Empty and dry the alcohol bottle, then remove the label.
STEP 3: Step 3
Using a piece of string or a rubber band, draw a guide line around the bottle with the Sharpie marker.
STEP 4: Step 4
Using the scissors, cut the bottle on the guide line.
STEP 5: Step 5
Mark a similar guide line at the top shoulder of the bottle with the sharpie and cut on that line as well.
STEP 6: Step 6
Now slip one end of the bottle over the top of your flash and put the large paper clip on the end of the bottle opposite the flash.
STEP 7: Step 7
Use the Sharpie marker and Paper Clip to draw nice guide lines -- the rounded end of the clip makes drawing a curve easier.
STEP 8: Step 8
Mark a line across between the two guide lines you just made, and also curved lines at the top on each side.
STEP 9: Step 9
Cut the section you just marked on the guide line.
STEP 10: Step 10
Now mark dots 3/8 inch up from the bottom of the bottle edge opposite the cutout that you just made. This edge will be towards your flash in the finished product.
STEP 11: Step 11
Make six such marks, two on the long side and one on each of the short sides.
STEP 12: Step 12
Use your tiny hole punch to punch out the dots.
STEP 13: Step 13
Now cut your velcro hook parts into three equal sections, and further divide one of those sections into two smaller sections. Round the bottom corners and transfer markings to the velcro to match the holes you just punched in the plastic.
STEP 14: Step 14
Use your tiny hole punch to punch out the marking dots on the velcro.
STEP 15: Step 15
Now, use an industrial hand press to apply the poly-resin snaps to hold the velcro to the plastic bottle. If you do not have such a press, punch additional holes in the velcro and bottle and use a needle and thread to attach the velcro to the bottle.
STEP 16: Step 16
Fold the 2 wide Velcro loop section and wrap it around the top edge of your flash unit, using a little piece of hook section between the flash unit and velcro loop to hold it snugly in a circle.
STEP 17: Step 17
Use the velcro hook bits on your diffuser to attach the diffuser to the loop part of the velcro on your flash unit, and you're all set to go!
3 Comments
chuckr44 15 years ago
okto 16 years ago
fungus amungus 16 years ago
