Sphere Drilling Jig
Intro: Sphere Drilling Jig
Cutting and drilling round objects is both difficult and dangerous. This is a step by step guide to making a jig to help drill spheres.
I recently posted a similar Instructable about how to make a jig for cutting and drilling cylinders which can be viewed here (https://www.instructables.com/id/Safely-Cut-a-Chane...
You will need:
Plywood (about 14 by 6 inches or more)
4 3.5 inch 1/4 20 bolts
8 1/4 inch washers (or 4 washers and 4 t-nuts)
4 1/4 20 wing nuts
1 inch forstner bit (or spade bit)
2 inch forstner bit (or spade bit)
5/16 inch drill bit
Safety Glasses
Pencil
Ruler
Table Saw
Drill Press
STEP 1: Mark, Measure and Cut
Cut your plywood into one 6'' by 6'' piece and one 6'' by 8'' inch piece. The larger piece will be for the bottom of the jig and will allow for easier clamping.
Next mark an X in in the middle of the 6'' by 6'' piece to find the center. Also make marks an inch away from each corner on the lines making the center X. The center X will be for drilling the hole that holds your sphere and the four corner holes will be for the bolts clamping everything together.
STEP 2: Drill
Stack the two pieces of plywood with the square piece on top. Line the square piece up with 3 of the 4 sides of the rectangular piece. Drill a hole with the larger drill bit directly in the middle of the two pieces. It is best to clamp the pieces on top of one another to ensure that the holes are lined up perfectly.
Use the 5/16 drill bit to make a hole at each of the marks you made an inch away from the corners.
Switch to the 1'' forstner bit and drill 3/8 inch deep pockets each of the 5/16 holes. Drill matching pockets on the bottom side of the rectangular piece too. These pockets will be where the washers or T-nuts go and also will create a space for the head of the bolt to rest so that the jig lies flat on the bed of the drill press later.
Try to keep the two pieces of plywood lined up well throughout all of this drilling. It will be easier to bolt everything together if the two sides match perfectly.
STEP 3: Add the Hardware
If you are using T-nuts insert them into the pocket on the bottom of the larger rectangular piece of plywood. and thread in the bolts. If you are using only washers insert them into the hole and thread a hex nut on the other side to keep the bolts in place.
Next, press in the washers into the holes in the smaller square piece of plywood and place it on top of the bolts. Thread the wing nuts on top of the bolts and your jig is pretty much finished.
If your marking and drilling was precise it should fit in any orientation. If your jig is like mine and the marking was not perfect it will only fit in one orientation. In this case it might be a good idea to put a directional mark on the top piece to remind you which orientation fits best.
STEP 4: Drill Your Spheres
Now you are ready to safely drill holes in spheres. Open up your new jig as far as possible and place your sphere in between the plywood pieces. This jig will only work for spheres that are large enough to make contact with the edge of the hole before touching the table. Tighten the wing nuts on the top evenly to clamp the sphere in place.
Once the sphere is securely clamped in place you can line up a drill bit on the center of your sphere and drill away. I used this jig for a project that will be appearing on Instructables soon.
10 Comments
snoopindaweb 9 years ago
OneHoleBull 9 years ago
What is the name and other info of the clamp used with the drill press??
CobyUnger 9 years ago
It is a great clamp. Here is a link.
http://toolguyd.com/woodriver-drill-press-hold-dow...
wbogen 9 years ago
This reminds me of a great puzzle: Take a solid sphere and drill a hole 6 inches long straight through it. When you set the resulting ring or mega-bead on a flat surface, with the hole pointing up, the object's height is 6 inches. What is the remaining volume of wood in the object, in cubic inches? It sounds like we don't have enough information: what was the diameter of the original sphere? What's the diameter of the hole? It turns out that none of that matters. As long as the original sphere was more than 6 inches in diameter (so you _could_ drill a hole 6 inches long through it), you will get the same answer, which I will leave as an exercise for the reader.
andrea biffi 9 years ago
yup, since the hole diameter doesn't take part in the calculation, you can try to visualize the two limits (zero and infinite) for that value. Infinite doesn't make sense, but with a zero diameter hole, the puzzle appears very simple!!
cyberdove 9 years ago
113.09733719999998 cubic inches.
wbogen 9 years ago
You are correct, cyber dove. There are two ways to solve it: with calculus or by using the formula for the volume of a sphere (Pi/6 x Diameter cubed) and a wee bit of logic. Which did you use?
TFS Jake 9 years ago
ooh neat! I figured it out once I realized the bit size would have to change to make it stay 6 inches long.
Wow what a cool puzzle. I'll think about that one and see what I come up with.
j-vega 9 years ago
A quick and ingenious solution.
