Spicy Hot Beef Jerky
Intro: Spicy Hot Beef Jerky
My husband is a big fan of beef jerky. This beef jerky is spicy with a nice hint of pepper. I bought a london broil top round to make it. I also dehydrated the meat in an Excalibur Dehydrator for exactly 4 hours and 15 minutes. A minimum of 4 hours is required to assure the meat has been heated enough to destroy pathogens. Adjust the amount of time after that. This will depend on how thin or thick you cut the meat and how soft or crispy you like your jerky. Slice the meat no thicker than one-quarter inch (¼") when making jerky at 155°F. Here is a link to the Safe Minimum Internal Temperature Chart. This recipe can also be found at gardengirlrecipes.com.
Ingredients:
2-2¼ pounds top round, eye of round beef, or flank steak
4½ teaspoons (20g) packed brown sugar
2 teaspoons (6g) garlic powder
4 teaspoons (20g) salt
2 teaspoons (4g) ground black pepper
3 tablespoons (40g) Worcestershire sauce
4 tablespoons (60g) Sriracha sauce
STEP 1: Trim & Freeze Meat
Trim the fat off the meat. You want to have 2 pounds of meat after all the fat has been trimmed. Place the meat in a ziplock back and place in the freezer for 10-15 minutes. This will make it easier to slice the meat.
STEP 2: Combine Dry Ingredients
Meanwhile, combine the brown sugar, garlic powder, salt, and pepper in a small bowl and mix well.
STEP 3: Slice Meat
Cut the meat into thin ¼" slices and place in a ziplock bag.
STEP 4: Add Dry Ingredients
Add the dry ingredient mixture and thoroughly mix together.
STEP 5: Add Wet Ingredients
Add the Worcestershire sauce & Sriracha sauce to the meat and mix well. Refrigerate overnight.
STEP 6: Spread on Racks & Dehydrate
Spread the meat out on the dehydrator racks without touching each other and dehydrate at 155°F for 4-6 hours.
20 Comments
kastmaster2105 6 years ago
I am reading 2----2 1/4 lbs of meat. Does this mean a total of 4 1/2 lbs? Or is this a miss print? Also, this amt. of salt seems way too much. The use of some Soy sauce sounds better IMO.
Garden Girl Recipes 6 years ago
Its a range: 2lbs to 2 1/4lbs. You can substitute the salt, if you prefer.
cheepwings 8 years ago
I've built screens that sit on an aircondioner filter on top of a box fan. I dry for 12 hours more or less. No heat and I've never had any problems with pathogens. Learned this technique from Alton Brown. Will try with your recipe.
GullReefClub 8 years ago
If I remember correctly AB used the box fan and AC\Heater filter for drying herbs not protien
Garden Girl Recipes 8 years ago
I'd love to see a pic
econjack 8 years ago
I don't have any drying racks, so I put a wood toothpick through one end of each piece and suspend the meat on the racks that come with the oven. I put a sheet of aluminum foil below the meat to catch any drips. I then turn the oven on as low as I can, crack the oven door just a tad, and let it dry. Depending on the temperature, it will take a few hours to dehydrate the meat.
I have read about many people using the oven method successfully.
PJSolarz 8 years ago
I've done the oven method with a lot of different things, meats, herbs, veggies. etc. It does work well as long as you regulate the heat correctly.
Post a pic when you do.
JoeyyBoyy 8 years ago
Did you purchase or make the dehydrator rack? Details?
I was actually given the dehydrator as a gift. However, I have seen a couple homemade dehydrators online and on the Instructables database.
20 in box fan elevated on paint cans. 1in x 1in wood frames, stapled stainless screen.6 frames, one to hold a.c. filter, one for cover, I find I can dry four lbs of jerky with this.
iFirefly 8 years ago
Do you know if Stevia can be used as a substitute for sugar? Additionally, I heard that the way that the meat is cut has a very big effect on how it turns out in terms of texture & chewiness and I was hoping to have seen more detail on how your method addresses this.
Stevia has a very unique taste. I'm not sure how it would taste in this recipe, but you should try it. As for the texture, I made this jerky using 2 types of meat. I cut the top round beef against the grain and the flank steak with the grain. The flank steak was chewier. I had a few pieces of the top round beef that were cut with the grain. They were also chewier.
rcaputo1 8 years ago
The teaspoon/tablespoon measurements are posted now :)
yopauly 8 years ago
just ask Google as a question. " How many grams in a teaspoon?" You'll find many things to help you.
deluges 8 years ago
This looks delicious ! And spicy
Thank you. It's spicy and very good. Hope you get a chance to try it.
