Spike Launcher
Introduction: Spike Launcher
This is a projectile launcher that I made with my dad (yes, I did say dad, I'm only 13). If you work on it straight through, it will probably only take two hours at most. A friend and I started making these with a straw, tape, and a rubber band. Then we got to legos, and finally a more permanent version. this will shoot barbecue skewers at high speeds, but I'm not really sure about how far in feet it goes. You'll have to try it out =)
P.S. You might want to add flights ( like feathers on an arrow) so the skewer will fly straight. If it flies straight and true, this is a killing machine, so be careful (and send me a pic of how you did it).
Step 1: Materials
plank of wood
PVC pipe
2 copper pipe-fasteners
2 cup hooks
2 eye screws
1 long rubber band
tape
4 screws
a lot of barbeque skewers
Step 2: The Barrel
I put 2 cup hooks in right on the edge of the base, then 2 eye screws in 13.5 centimeters behind those. The cup hooks are about 5 cm apart. Then, cut about 19.6 cm of PVC. Size doesn't matter, but the skinnier the better. Clamp the PVC down using 2 fasteners. You might find it necessary to take up some space in front so the barrel doesn't wiggle.
Step 3: The Firing Mechanism
Get a large rubberband. place it so the sides are about 1" apart and wrape tape around the middle to make the catch. Stretch the rubberband through the eyes into the cup hooks. Now head off to the firing range!
Step 4: Firing
to shoot, insert a skewer into the front end of the barrel so the back of it hits the catch. Pinch the tape around the skewer, pull back, aim, and let go. I shouldn't have to tell you to be careful, because even if there aren't any flights, it can still pierce skin and mortally wound.
Be the First to Share
    • Anything Goes Contest
    9 Comments
    banana fluff
    banana fluff
    12 years ago on Introduction
    im glad you are doing things with your dad. Im 15 and still love building stuff with my dad. There arent too many kids who care about that bonding time
    SirNoodlehe
    SirNoodlehe
    kool, I made something similar when I was 10, not as kool though
    Modarius
    Modarius
    13 years ago on Introduction
    My cousin and I made something similar only it looked like a crossbow and had a clothes pin for a trigger. Definitely fun and dangerous, Every thing a 14 year old could ask for, right?
    climbermaniac7
    climbermaniac7
    Reply 13 years ago on Introduction
    ya. my friend and i started with a straw and rubber band. we thought that was so cool, so we built one with legos for a more permanent feel. then i got the idea to make a more powerful one, hence wood and PVC. if you want me too, i'l post an instructable for the straw version. you can make it in about 5 minutes.
    climbermaniac7
    climbermaniac7
    ok... i'm leaving on spring break, so should be up after break
    climbermaniac7
    climbermaniac7
    sorry guys it's not up... i'm bogged down with so much homework i barely have time to do anything. i'll get it up as soon as i can. thanks for bearing with me.
    wolfman2152
    wolfman2152
    this... is... so... AWSOME... everyone needs to make it. It may not look cool, but very effective!
