Sports Drying Rack With Fan
Intro: Sports Drying Rack With Fan
STEP 1: Sports Drying Rack Materials
1in PVC Pipe Lengths
1:2ft
2:17in
2:14in
2:12in
6:8in
3:6in
1:4in
1:3in
2:3 Point connectors
3:4 Point connectors
6:90 Degree connectors
9:1in capes
PVC Glue
1 Bathroom Fan
Drill with Drill bit
STEP 2: Feet
-Connect two 8in pipes to one 3 point connector and put capes on both ends like in the picture.
-Connect two 13in pipes with a 90 Degree connector and add to first peace.
-Make two of these and connect them with a 4 point connector.
-Use PVC glue on all of these peaces.
STEP 3: First Tier
-Connect two 17in pipes to the sides of a 4 point connector.
-Connect tow 8in pipes to the ends of those with 90 degree connectors.
-Put a 4in pipe on the bottom of the 4 point connector.
-Add capes to the tops of the ends.
-Use PVC glue on all of these peaces except for the the bottom of the 4in peace that connects to the base.
STEP 4: Second Tier
-Connect two 12in pipes to the side of the last 4 point connector.
-Put two 6in pipes on the side with 90 degree connector with capes on top. Also put one of those in the middle with a cape on top.
-Connect the 2ft pipe to the bottom of the 4 point connector.
-Use PVC glue on all of these peaces except for the bottom of the 2ft pipe so it can be disconnected for storage.
STEP 5: Fan System
-Connect the fan with a connector that goes from the opening of the fan down to the 1in size of the pipes.
-Then connect that to the bottom of the base where the opening is on the 4 point connector.
STEP 6: Assembly
-Drill holes into where you think you need them but not to many that the air isn't strong.
-Connect all the peaces to gather as seen in the pictures and use this to dry all kinds of sports gear.
2 Comments
thriza 3 years ago
DIY Hacks and How Tos 5 years ago
Nice. It could also double as a coat rack.
