Spray Painting a RipStick / Wave
Intro: Spray Painting a RipStick / Wave
STEP 1: Materials
-Screw Driver
-Masking Tape
-Clear coat paint
-Cardboard
-Alen wrench
-Sand Paper
-Box Cutter
-Marker
STEP 2: Disassembiling
When you get all the screws off you will want to take a really thin screw driver and push it through the hole where the big screws were to push off the face plates.
You should end up with
2 alen screws
8 small regular screws
9 big regular screws
2 face plates
4 grips
1 middle rod
2 main parts
STEP 3: Making the Stencil
You want to pick out your picture and cut it out and trace the inside on to a sheet os cardboard when you have done this you want to cut it out so you end up making a reusable stencil.
STEP 4: Painting
Started by painting the grips then i put tape on the main boards to only paint the small grips next i painted the metal rod in the middle rod
I painted the face plates last because it had most design on it but you can paint it in any order you want.
I paint the face plate yellow then took the tape and put it on the sides to form a strip in the middle and painted it green.
You dont have to do exactly what i did you can do any design you want.
Once you have everything else painted you can tape the stencil on to either face plate and spray it any color
When you are done painting you would want to spray everything with a clear coat to keep the paint on.
