Introduction: Sprout Seeds Overnight...with Scarification!
How would you like to sprout practically any seed overnight? Of course you would!
I like to mess around with plants, but I have always had a hard time getting seeds to reliably sprout, or germinate.
Yesterday I was poking around the web trying to learn more about how to get seeds to sprout with more success, and I found a reference to something called "seed scarification". This is a fancy way of describing the method of nicking, sanding, or clipping off part of the seed's shell so water can get to the inside part to activate germination. You can search YouTube to see a selection of videos on this topic.
The reason that seeds take varying lengths of time to germinate is not because the inside of the seed takes more or less time to activate. It is simply because all seed shells are somewhat water-resistant. The germination time has to do with how long it takes water to penetrate and permeate the seed shell or coating and get to the inside part of the seed. Once the water reaches the inside of most seeds, they all activate and grow immediately at that point.
Yesterday when I found this method, I tried sanding one edge off each of ten pumpkin seeds. The previous two attempts at germinating these same commercial pumpkin seeds resulted in only one sprouted seed from the 20 that I attempted to germinate. But of the 10 pumpkin seeds from the same package that I sanded one edge off and started germinated yesterday, already today 6 of the seeds have sprouted with up to 1/2" long roots! That is less than 24 hours!
So although this is a very simple Instructable, I hope that it will help a lot of you that like to grow plants from seeds.
Let's get started, shall we?
Step 1: What You'll Need...
You will need:
o Seeds, dried
o Some way to damage the seed shell (I used 220-grit wet-and-dry sandpaper, but you can also use nail clippers or fine metal file, etc.)
o Water
o Paper towel (optional)
o ZipLock sandwitch or snack bag (optional)
That's it!
Step 2: Now Damage the Seed Shells...
Grab one of the dry seeds and damage the side of the seed shell by sanding through the shell with sandpaper, or by nipping off a tiny piece of the seed shell, or by filing the side of the seed shell.
You don't want to sand or cut ot file past the seed shell. When you reach the inside part of the seed, you have gone far enough. The idea is to allow water to enter the inside of the seed shell by capillary action to distribute the moisture.
If you sand or cut or file too far into the inside part of the seed itself, you might damage the seed and then it will not germinate.
Trial and error is required until you get the hang of it.
Step 3: Water the Seeds and Germinate Them...
You can do this step a lot of different ways, but the way I like to do it is as follows:
o Moisten a paper towel with water and then ring it out so it is damp but not dripping. It should be fairly dry.
o Arrange the scarified dry seeds on the folded paper towel. I usually do two rows of 5 seeds for a total of 10 seeds.
o Carefully place the paper towel with the seeds on it into a ZipLock sandwich or snack-sized bag. Squeeze all the air out and seal the bag.
o Put the bag with the seeds in it in a warm area. I have a proofing oven for bread that I like to use, which keeps the temperature at about 90 degrees F which seems to be optimal for most seeds.
o With luck, you should see your seeds sprout roots within 24 hours.
I hope this helps you find more success in germinating seeds!
Great Outdoors Contest
4 People Made This Project!
- OceanWhisper made it!
- PaHalloweenFreak made it!
- justj700 made it!
- Dracoraptor made it!
157 Comments
1 year ago
Im trying it right now yt
6 years ago
I wonder if the quality of municipal water has an effect. Ours has a lot of chloramine and probably other residues.
Reply 2 years ago
Put water in a jug / container and leave uncovered for 24hrs and the Chlorine will have off gassed out of the water!👍
Reply 6 years ago
I'VE BE TOLD THAT IF YOU LET MUNICIPAL WATER STAND UNCOVERED THE ADDED CHEMICALS WILL EVAPORATE . MAYBE SOMEONE ELSE WILL BE BETTER ABLE TO ELABORATE ON THIS . I ALMOST ALWAYS USE "CITY" WATER AND HAVE DECENT LUCK , ESPECIALLY FOR SOMEONE WITH A " BLACK" THIMB !
Reply 6 years ago
municipal water is full of chemicals . I let water stand in the sun covered to keep out insects , for a week to let chlorine and chemicals dessipate . It is then safe to use even for fish without adding extra chemicals . Interesting facts about municipal water especially where it is recycled is that it has been through 9 sets of kidneys before you get to drink it . Hormones are very difficult to remove from recycled water and some suspect that this , especially hormones found in birth control and menopausal medication could be causing changes in men's sexuality ? . ( iIt has been suggested ) and that ! Lastly , Londons water has detectable amounts of cocaine in it . Nice !!!!
Reply 6 years ago
I boil "distill" my water and cover with a paper towel while it is cooling to room temp. That way I get all chemicals out of it. I've been doing it for years (since a teen) and I use the water for my dogs drinking bowl, to water my urban garden, for myself and for my betta's water. Never had an issue and I've even done the experiments between bottled water, tap water and boiled water. So far, boiling the water wins every time when it comes to my betta's being happy and healthy(they don't get that slimed skin and other health issues) and my garden is always lush, green and when it's time to bear vegetables and fruit, mine grow big and tasty. Of course I also add food to the soil but my hydroponics with just water do fine.
Reply 6 years ago
Hi. I just want to mention that boiling the water is fine, it will kill bacteria, but "distilling" it means turning it completely to vapor and re-condensing it through a cold coil, which is the only way to create distilled pure H2o, which is NOT good for pets or humans. Trace minerals are necessary in the water we drink. It is always a good idea to have your water tested for what it contains, especially after the Flint, MI fiasco. You should try that before and after you boil it to see what if any differences there may be. Any urinalysis lab can do it.
Reply 4 years ago
In recent news, our local school board in Hillsborough County has allowed lead tainted water in schools.
Reply 5 years ago
Are there home tests for water out of the tap? I am atuned to soil contamination never thought 2x about h2o - I feel rather dumb
Reply 5 years ago
No wonder Londoners have 'high' water bills
Reply 6 years ago
Actually chlorine is a very Volatile chemical and should evaporate in one day left UNCOVERED it can not evaporate if it is covered.
Reply 6 years ago
Hi CLEM2, While it is true that letting water stand open in sunlight for 24-48 hours will cause chlorine (toxic to plants) to dissipate, it will will do almost nothing to address chloramine (also toxic to plants and used in place and/or in addition to chlorine by most municipal water services for years now). Running tap water through a water filter that contains activated carbon and KDF elements will greatly reduce chlorine and chloramine levels. You can eliminate the remainder of chlorine and chloramine in your water by adding a small amount (~ 1/4 tablespoon per 10 gallons) of sodium ascobate powder (a specific form of vitamin-C available online and in local nutrition stores). -- Happy Growing! -Joe D.
Reply 6 years ago
In any significant concentration, chloramine is not good for living things. It sounds like your water is tested for, which means it is likely below the problematic limit. But we know from Flint, Michigan that is not always the case.
2 years ago
Wonder how this could go with really fine seeds such a Eucalypts? Most Acacia seeds I hot water scarify....
3 years ago
I managed to germinate seeds with out damaging the seed just put them a a seal bag with wet tissue sealed the bag up... then placed it on top of my internet router next day the seeds has sprouted :-D
6 years ago
Thanks! Definitely going to try this.
6 years ago
I am so dense despite my IQ!! I've nicked my Morning Glory seeds & soaked overnight for years because their outer covering is extremely hard. I've used razor blades & utility knives. It never crossed my mind to use clippers, which I'm sure are stout enough to cut through the hard shell. Thank you for posting.
6 years ago
U r a genius
6 years ago
6 years ago
I have apple seeds I'm going to try this with...sounds great!!!!
