Introduction: How to Successfully Clean a Nasty Plastic Bowl Stain.
When you make spaghetti or something that stains in Your Gladware, im going to show you how to prevent it and how to get rid of it if you forgot to prevent it. Piece of pie, Easy as cake. Backwards?
Step 1: Identify the Culprit
yes well look at the dish with the nasty red spaghetti sauce and think, how can i prevent this? Well, if its a temporary place for the food, like a day, just spray it down with some Crisco spray or something in that category. otherwise, read on.
to get rid of it you will need:
A Stained Bowl
Clorox kitchen cleaner
some water
and if its bad, a scrubber brush or sponge
A Stained Bowl
some water
Step 2: Real Step 1
Grab the Bowl and give it a quick rinse.
Spray it down a bit with bleach cleaner and add a bit of water, then let sit.
Step 3: Then...
After letting it sit for just a bit, not very long, rinse it out a little and wash it like you normally would, and if you need to scrub it a bit like i did and re wash it. Given you handwash dishes...
Step 4: You Should Be Done
you should be done and with clean bowls. i know the last bowl isnt the same one, but i also used it for spaghetti sauce.
