Star Wars 74-z Imperial Speeder Bike
Intro: Star Wars 74-z Imperial Speeder Bike
I made a Star Wars 74-z Imperial Speeder Bike because I love Star Wars and woodworking so I thought it would just be a fun project. It is actual life size. reaching 9' long. It is made 100% from wood
STEP 1: What I Am Making and Using
I started with an image of the Speeder Bike and a pile of wood. Lots of scraps worked perfectly. I did my research on size dimensions and some well educated guessing.
STEP 2: The Frame
I started with a 2"x4" frame and the front forks. It is all screwed and glued as it will be sat on by adults.
STEP 3: Improvising Legs
Since the Speeder Bike flies, it doesn't have legs BUT for mine to be able to sit at chair height I created legs in a "Star Wars" style. Using 2"x4" and 3/4" plywood I created supports that look like they may have been there all along. 2 in the back and 1 in the front.
STEP 4: Front End Details
Creating the front of the body details is not only for looks but also to make the bike solid and rigid. The dowels are 2" and run into the main body frame.
STEP 5: Taking Shape
The very front of the forks has a distinct look which I used a left over furniture spire. The tank starts to take shape using 1/8" Masonite board, wood glue and screws.
STEP 6: Legs Attached and Undercarriage Paint
The legs are attached to the frame and secured with wood glue and screws. Everything is given a base coat of primer, black paint and grey paint. It is worked with spray and brushes to create the look of distressed metal.
STEP 7: Adding Steering Components
The Components of the steering are again made out of wood. Dowels double as metal tie rods. Painted to match the rest of the metal.
STEP 8: Seating and Rear End
The rest of the body was finished in Masonite and the seating area with 3/4" plywood. The rear end uses layers of Masonite and plywood.
STEP 9: Front Fins and Steering Arms
The front fins are made from 1/2" plywood attached with glue and screws. The steering arms are made from shaped 2x4"s and 1" dowels.
STEP 10: Painting the Steering and Fin Details.
STEP 11: Body Paint
Painted the body panels with a distressed Brown with black. Taped off all the components I didn't want to get overspray on. All the details of colors were added here.
STEP 12: Final Details
The seat was made from vinyl from a Chevy Chevette. Rear Thrusters were painted. Fish pond hose was used for the wiring on the under side.
STEP 13: Finished 74-z Imperial Speeder Bike
The finished 74-Z Imperial Speeder Bike 9' x 24" High can hold over 250lbs. This was a fun project that was made entirely from wood... minus the seat cover and hose.
5 Comments
wraytammy90 5 months ago
RoccoM 5 months ago
DragonFlame13 1 year ago
seamster 1 year ago
RoccoM 1 year ago
