Introduction: Starship Zeta Made for Time
Starship zeta is a craft made for time. Its design features a non-friction resistant haul. It has a carriage and fusion propulsion. It was to improve the time of travel.
Onshape was used to produce the 2D drawing and convert into a 3D design.
Shapeways was used for 3D printing.
Step 1: Starship Zeta Stand
1.1 The lower stand was made from a rectangular sketch and an incline extrusion.
1.2 The middle section was a rectangle sketch and chamfer extrusion at the upper and lower regions.
1.3 The upper section was a semi-incline sketch extrusion.
Step 2: Starship Zeta Haul
2.1 The starship zeta haul was made from a rectangle extrusion with a incline in the midsection extrusion.
2.2 The sides were made with an extrusion cut along a path in the perpendicular direction.
2.3 The carriage was made from sequence of trims of a semi-circle. This was revolved over the carriage at 90 degrees.
2.4 The haul seat was made with two extruded rectangles on each other and chamfered at the sides.
2.5 The driver was made with a circular upper extrusion and then in the perpendicular direction. This was left with uneven sequence of cones.
Step 3: Starship Propulsion
3.1 This inner section was made from a two cylinders extruded with an uneven sequence of revolves.
3.2 The middle section was extruded with a smaller size cone of the same design of the inner cylinder.
3.3 The outer section was made with the same design and size as the inner section extrusion.
Step 4: Starship 3D Printing
4.1 The 3D design was exported from onshape.
4.2 This was imported into shapeways.
4.3 The design was made from White natural versatile plastic.
This is an entry in the
Making Time Contest
