Introduction: Wearable Stay Puft Marshmallow Man Costume
Step 1: Step 1: AC/DC?
The first step I would need to do is check to see if the fan motor will work on a portable DC power source. I was a little bit saddened when I read the sticker on the power supply. It read output voltage 12vac. If it was a synchronous motor the whole project would be canned but it turns out that when I hooked up a 12vdc power source the fan turned on and worked as it normally would. So I am guessing that either the label was printed incorrectly or the LED’s inside some how were part of an H-bridge to convert AC to DC.
Step 2: Step 2: Power
Next I had to find a 12v battery that would last long enough to keep this costume inflated at a party. This was done by using an old gel battery from a batter back-up. So I cut the wire that went to the wall adapter and soldered on some flat connectors that would allow me to connect to the battery. After testing the motor on this new battery the first thing I noticed was how heavy the battery was. So I decided to make a way to attach it to my belt. This one done by using a plastic coat hanger (the kind with the metal swivel hook at the top). I cut the hanger down to the length of the battery and used some duct tape to fasten it. I bent the metal part of the hanger to be more narrow and hung it from my belt. It was a little uncomfortable in the beginning but as I re-positioned it and bent it different ways it was not as bothersome anymore.
Step 3: Step 3: Sewing
Now I needed a way to get into the costume. I noticed that there was a small zipper on the back to aid in the deflating process. So I figured I make that wide enough that I can fit into it. I took a trip to a local Walmart and picked up a 24” heavy duty zipper. If I could have done it all again I would have got a 36” zipper. The 24” works but is a little snug getting into it. I cut the costume along the seam to the length of the zipper. Before I added the zipper I took the time to fold back where I cut and stitched the flap on each side as well as some extra stitching around the very ends for strength. Then I stitched in the zipper. After watching a Youtube video on sewing I decided to go with a straight stitch as it was the simplest and fastest one I can find. To do a straight stitch just bunch the fabric together so it makes multiple MMM shapes then push your needle through the arches. Don’t make too many arches or it will be difficult to pierce with the needle and pull the thread threw.
Step 4: Step 4: Trying It On
At this point I went outside and tried it on, cool! It filled up and looked great, but there were 2 problems. The most annoying issue was the fact that I couldn’t see anything when in side of it. Even if I put my face up to the material I couldn’t see anything! The other problem was the fan dragged on the ground and clogged up with the material so the costume would start to deflate.
Step 5: Step 5: the Window
I went to a local fabric store and purchased some thin transparent plastic. I had to but it by the yard so I still have a lot left over. I measured a piece that would go right behind Stay Puft’s scarf. I did this so If I wanted to use it as a decoration later or scare people with it, it would still look like a lawn decoration. I cut the costumes fabric and stitched the flaps back like I did with the zipper. Then I overlaid the plastic and and used duct tape around the edges to make it air tight and give it a boarder. Lastly I stitched through the tape, plastic, and folds. the whole way around to make it strong. Now I am able to see out of the Stay Puft costume.
Step 6: Step 6: Inflation
The last obstacle I needed to overcome was to hold up the fan so It didn’t drag on the ground. Although this was the toughest thing to figure out it was actually the easiest thing to do. I’ve determined that I will stuff Stay Pufts feet into my shoes to save them from becoming ripped and also give me something comfortable to walk on. The fan is located in Stay Pufts heal / ankle area which just so happened to be right on the upper back part of my shoe. I took a metal coat hanger and bent it in an L shape and placed the one half inside my shoe under the padding and above the sole. I was able to widen the metal coat hanger and fit the fan into it securing it against the back of my leg.
Step 7: Step 7: It's Alive!
Second Prize in the
Halloween Epic Costumes Challenge
1 Person Made This Project!
- macgeek made it!
12 Comments
6 years ago
Do you rent it out?
7 years ago on Introduction
My mother works for a radio station and let's just leave it to say that they had a giant 10' inflatable chicken costume that went with some of their programming. In many ways it wasn't much different than what you have here. The only real differences are that the feet were flat and some sort of stiff board on the bottom with two velcro straps that came up over my shoe. The battery and fan were attached to a heavy 5in or so nylon belt that was held by velcro and the fan had a tube of the same nylon material that went down to the costume to help fill it up. So you're right on track with what is professionally done. It's a hilarious costume and brought back some fun memories!
9 years ago on Introduction
My day has started with a chortle; very funny Instructable-Thank you.
10 years ago on Introduction
This is awesome. How easy do you think this costume would be to run long distances in (3-4miles)? Any changes you could make so it would be easier? If I'm 6'4", where would my face end up inside the costume? Thanks.
10 years ago on Step 7
2 words: Porch Lights
I was gonna kill myself today, but you saved me! LOL
Hahaha, awesome. Where in the world did you find a Stay Puft Marshmallow Man lawn decoration?
www.80stees.com/
Thanks! A lot of people laughed too when they saw it. I got it from 80sTees.com
That is a great costume! Was it difficult or fun to wear, or both?
Thanks, It was quite fun to wear. Although I would make some changes to it to make it easier to wear in the future. One Idea would be to add a straw of sorts for a beverage or an access port to get things into and out of it! With that aside it was a blast to wear!
That's fantastic! I just might have to give that a go next year :D
Ah-mazing! So cool to see it on Subbass this morning, and here now! Really impressive work.
