Steampunk Shutter Shades
Intro: Steampunk Shutter Shades
Ever want to look like a rapper from the 19th century? Well then, today's your lucky day because this Instructable will teach you how to make a pair of steampunk shutter shades! They are pretty easy to make once you get started and look nice when worn on the face, hat or around the neck.
STEP 1: Materials
Items needed:
Circular vent covers (aka soffit vent grilles)- just a dollar from the hardware store
Simple leather purse- Goodwill
Maybe a clasp or buckle- may come on the purse or fabric/hobby store
Tools:
Scissors
Crazy glue
Tools:
Scissors
Crazy glue
STEP 2: Preparing the Vents
To prepare the vents you must first remove the wire mesh. Just put your screwdriver into the middle of the wire and use the edge of the vent as a fulcrum and the mesh should just slide out in one piece.
Next, wedge a blade of your scissors under the lip of the ring that goes around the actual vent and cut- it'll just pull off then. My vents are made of tin so they were no problem to cut, but they are also a little easy to bend out of shape so be careful about that.
STEP 3: Cut Up the Purse
Now find and cut out an area of the purse with no seam that is large enough to cover the vent and wrap around to the back. Once that's out, trace the outline of the vent part that sticks out in the center of the leather. Remember when you cut out the circle that it's better to cut too little than to cut too much. Next, fit the vent though the new cut and repeat for the other eye.
STEP 4: Crazy Glue and Scissors
Glue down the leather where it touches the tin. Then cut off the leather that won't touch the rim of the vent when folded tightly down. This next part will take some time and precision: cut V's (not y's, the edges overlap and make the border look lumpy when glued down) into the leather and glue the flaps down. Also do this to both vents.
STEP 5: Connecting the Vents
Now take a piece of the purse strap that is long enough to go across your nose and fold over the sides of the vents. Cut the strap so only the bottom piece of leather can fold into the vent wall by cutting off the seem and top layer of leather. Make sure the vents' slot are horizontal and then glue where the leather folds are and to the tin sides after.
STEP 6: Headstrap
Once you have a another piece of the strap that is long enough to go around your head and fold into the vents, do you same as you did attaching the vents together. You may want to add a buckle or a snap of some kind as a way to secure the goggles on, but I just oped for the simple band. Once that's done, you have a nifty pair of steampunk shutter shapes that you can see out of pretty well.
57 Comments
Tobi Davis 8 years ago
Awesome. I'm so going to make this to go with my top hat.
Triggerhappy101 9 years ago
**Looks at map.*** WE HAVE TO GO THIS WAY! ***Falls off cliff***
lol
CrystalB01 9 years ago
Win Guy 11 years ago
make...
these...
GAAAH! Too awesome. Thanks so much for this 'ible!
modog4000 12 years ago
acidbass 14 years ago
st.paul 14 years ago
monsterlego 12 years ago
acidbass 12 years ago
hvargas 12 years ago
st.paul 12 years ago
that's about the closest thing i could find. from there, you might want to do some more looking online. when i made these, i didn't realize how hard to get those vents are.
Jew934 13 years ago
st.paul 13 years ago
Ryutso 13 years ago
SLRMC93 13 years ago
:D
H-Sama 14 years ago
