Steel Mirror
Intro: Steel Mirror
In this Instructable, I will show you how to convert a piece of steel sheet into a mirror.
STEP 1: Dry Sanding
I started by sanding with 100 grit and then used a nylon fiber wheel to clean the dark spots.
STEP 2: Wet Sanding
Then, I switched to wet sanding and went from 380 to 2000 grit. Remember to switch your hand movement pattern between horizontal and vertical every step you go further, and also, do not try the circular paterns.
STEP 3: Polishing
The last step is polishing; I added some of the soft polish paste I use for my car's paint and started the polisher. After this step, your errors from the sanding process will be visible to you; mine was far from perfect but acceptable.
STEP 4: Result
Now you have a shatterproof mirror! I hope you enjoyed this Instructable. If you have any questions or suggestions for me, please leave a comment. I will reply as soon as I can. You can also check the video tutorial of this project by clicking on the video, which is located at the top of this page. Please feel free to ask any questions in the comment section below and
also, you can check my YouTube channel for more projects like this.
