Introduction: Steering Wheel Holder / Soporte Para Volante
I am a person who loves hobbies, from modeling to DIY projects and also simulators.
Today I bring you this project that occurred to me there in 2021.
At the beginning of buying the g29 wheel, I always left it mounted and enjoyed the ets and ats continuously. But little by little I needed the PC for other things and I had to disassemble it and store it somewhere that wouldn't get in the way much and wouldn't collect dust. At first it was a wardrobe, but what happened? I started to stop taking it out because of the laziness of having to move a lot of things and stop using it.
So one day I decided that it was time to start using it again and it occurred to me to make a support for it to store it under the table, preventing it from collecting dust, getting in the way and making me lazy to remove it. For me, a complete success.
Soy una persona a la que le encantan los hobbys, desde el modelismo hasta los proyectos DIY y tambien los simuladores.
Hoy os traigo este proyecto que se me ocurrio alla por el 2021.
Al inicio de comprar el volante g29, lo dejaba siempre montado y disfrutaba de el ets y ats continuamente. Pero poco a poco fui necesitando el pc para otras cosas y tenia que desmontarlo y guardarlo en algun sitio que no estorbara mucho y no cogiera polvo. En principio fue un ropero, pero que ocurrio? Comence a dejar de sacarlo por la pereza de tener que mover muchas cosas y deje de usarlo.
Así que un día decidí que era hora de empezar a darle uso de nuevo y se me ocurrió hacerle un soporte para guardarlo bajo la mesa evitando que cogiera polvo, estorbara y me diera pereza sacarlo. Para mi, todo un éxito.
The materials are bare:
- 12 6x30 Screws (Although it really depends on your table)
- 50cm V-slot aluminum profile 2020
- A printer to print two pieces
Los materiales son escuetos:
- 12 Tornillos 6x30 (Aunque depende realmente de tu mesa)
- 50cm Perfil de aluminio V-slot 2020
- Una impresora para imprimir dos piezas
Step 1: Print Parts / Piezas a Imprimir
The design is made in tinkercad, it is very basic and simple (sometimes it is the best :)) It consists of three legs to screw to the bottom of the table and a hole to insert the v-slot.
Actually it is the same design but doing symmetry, however I leave you the two stl in case you need it.
I also add the link to the piece in tinkercad in case instead of a v-slot, you want to add a round linear rod or even a rope with two knots.
El diseño esta realizado en tinkercad, es muy básico y simple (en ocasiones es lo mejor :)) Consta de tres patas para atornillar a la parte inferior de la mesa y un agujero donde insertar la v-slot.
En realidad es el mismo diseño pero haciendo simetría, no obstante os dejo los dos stl por si lo necesitáis.
También añado el link a la pieza en tinkercad por si en vez de un v-slot, queréis añadir una varilla lineal redonda o incluso una cuerda con dos nudos.
Step 2:
Screw it under the table and attach the steering wheel. This support has been created for the logitech G29 wheel and I can't tell you if it would work with another model since I only have this one. On an ikea table and with an ikea chair, it fits perfectly. even tucking the chair under the table.
Atorníllalo bajo la mesa y coloca el volante. Este soporte a sido creado para el volante G29 de logitech y no puedo decirte si funcionaria con otro modelo puesto que solo tengo este. En una mesa de ikea y con una silla de ikea, cabe perfectamente. incluso metiendo la silla bajo la mesa.
Step 3: Finish / Fin
Spin it, an enjoy!
I hope you liked it and you are encouraged to do it. If you have any questions, suggestions or confusion, do not hesitate to leave your comment, I will be happy to help you. Don't forget to follow me on instagram @modelkitsdeluxe for more kits and work in progress!!
I have carefully reviewed the project and I have done it as I propose it in this intructable so that you do not have problems when doing it yourself and do not waste your time, however, if you see something strange, I appreciate your collaboration.
Lastly, I'm sorry if something strange slipped into my translations, I always check them, but it can happen.
Dale la vuelta y a disfrutar!
Espero que os haya gustado y os animéis a hacerlo. Si tenéis alguna duda, sugerencia o confusión, no dudéis en dejar vuestro comentario, estaré encantado en ayudaros. No dejéis de seguirme en instagram @modelkitsdeluxe para mas cacharros y trabajos en curso!!
He revisado cuidadosamente el proyecto y lo he realizado tal cual lo propongo en este intructable para que no tengas problemas a la hora de realizarlo tu y no malgastes tu tiempo, no obstante, si veis algo extraño, agradezco vuestra colaboración.
Por ultimo, lamento si alguna cosa rara se me coló en las traducciones, siempre las reviso pero, puede pasar.
Organization Challenge
