Introduction: Stencil Brushing Ring 手工拉丝戒指
I design this process named stencil brushing. It can help you make your own pattern in many kind matiarials like metal plastic ... even kids can do it.
Essencial process :first apply stencil then brushing it
What you need:a piece of tape、a silver 925 ring、a nail polish stick
Description:Soft matiarials have better effect than hard matialrial .Metal like copper 、aluminum 、silver or soft steel is highly recommended
My english is not very good.
For better under standing the process ,you would better watch the video
本人开发这个工艺取名叫模版拉丝或者花式拉丝,它能让你在金属或者别的材质上做出你想要的图案,而且你还可以随时轻易的修改它。小朋友都可以掌握它
所需物品:胶带一条、美甲抛光条一个、925银戒指一个
说明:本工艺可以使用在各种材质表面,软的材质效果更好。金属材质如铝铜银还有软的钢材有特殊反光效果尤其推荐 过程简介:先贴胶带再拉丝,不断重复做出图案
本人英语能力一般,如果有疑问请观看视频
Step 1: Stick Tape to the Ring 在戒指表面贴胶带
Step 2: Brush the Ring in One Direction 沿着一个方向打磨
Use the polish stick to brush the ring in one direction .And then remove the tape.You can see a clear line between along the edge of tape
使用抛光棒沿着一个方向打磨,然后取下胶带。可以看到沿着胶带有清晰的线条和图案
Step 3: Repeat Step1-step2,stick Tape and Brush Again and Again 重复第一步和第二步,不断贴胶带和拉丝
description:
1.You would better change the brushing direction every time you stick the tape.If so you can make cool effects
2.If you always brush the ring in one direction you will make special effects,you can try it yourself
说明:
1.每次贴胶带后,打磨的方向最好不同,这样可以做出清晰的图案
2.如果一直沿着一个方向打磨可以做出特殊的效果,有条件可以自己试一下
Step 4: Finish It Until You Safisfy 满意后结束
You can change the pattern anytime if you do not like it anymore.
如果不满意,您可以随时更改它。
Stick It! Contest
