Introduction: Step-by-Step Easy Loom Band Bracelet/Hair Srunchie
This bracelet is for beginners, but you can also use it to tie up your hair or give it to your BFFs. It’s super-easy, and any questions you can simply type in the comment section:)
Step 1: You Will Need...
To make a single chain loom band bracelet, I use 10 yellow bands and 9 pink bands for this one. So make sure that you have:
1) 10 yellow bands 2) 9 pink bands
3) Loom (it’s okay that my look is not the same as yours)
4) One hook
5) One S-clip
4) One hook
5) One S-clip
Step 2: Placing the Bands
Make sure that your loom is facing up. Then, place a yellow band on the 1st central peg and stretch it across two the 2nd right-hand peg. After that, place a pink band on the 2nd right hand peg (the yellow band is under it) and onto the 2nd central peg. Continue your way up until there’s none left, as pictured. Turn the loom around.
Step 3: Start Looming
Then, pull the yellow band on the 1st central peg up and onto the 2nd left-hand peg (the purple band is under it). If you can’t get it, please refer to the video.
Step 4:
Once you’ve gotten the hang of it, pull the purple band on the 2nd left hand peg onto the 2nd central peg.
Step 5: You’re Almost Finished!
Continue your way up the loom by repeating Step 3-4.
Step 6:
Take the top yellow band off the peg with your hook. Pull your bracelet off, but leave the last band (yellow) on the loom.
Step 7: Almost Close to the Finish Line...
Attach an S-clip to the top yellow band, make sure that both loops of the band are on the S-clip. Then, you can take off the yellow band that was still on the loom and attach it on the other end of the S-clip.
Step 8:
When you’re confident, make more and switch colours! Thank you for following the steps!
