Stepper Motor Generator
Intro: Stepper Motor Generator
This instructable goes over how to create a generator to power lights, charge a battery or capacitor, etc. with kinetic energy.
Parts:
Stepper Motor (with 4 cables)
8 diodes
breadboard
a load to charge or power
Parts:
8 diodes
breadboard
STEP 1: Create a Bridge Rectifier Using 8 Diodes in a Diamond Formation
STEP 2: Bridge Rectifier Breadboard
STEP 3: Another View of the Breadboard With Everything Plugged In
Here is a project that I created using this circuit:
Circuit Board (A board that lights up using the kinetic energy of the spinning wheel)
15 Comments
Spektaft 4 years ago
The reason being that I can then only run two wires from the wind generator way up on the tower.
GitarthaG 7 years ago
what type of diode are u using
aizat0904 7 years ago
is this stepper motor can be use?
SkyRanger 8 years ago
What is the com link? And real photos I can base this off of? I'm a little new to cicrurtry, and I need help sooner than later
Just did a little research. It's an inductor and the other thing is a capacitor. Specs on those?
Dick_Knipple 7 years ago
Sky Ranger - in the circuit diagram the coils on the left are the actual stepper motor. It has two sets of windings (coils) and 4, 5 or 6 wires - com stands for common which is a centre tap on each of the windings and in this example is not being used. Although he shows capacitors in the circuit diagram I cannot see any on the breadboard, and there are none mentioned in the parts list. Make sure you connect the diodes the right way round, they are marked with a line or spot on the negative side. They only allow current to pass in one direction (not the cheesy boy band!) so if you get them wrong the circuit will not work.
JohnC386 7 years ago
is the stepper motor used for arduino capable of doing this? this is what it looks like:
17HS4401
StudentBuilds 7 years ago
Yeah it should be fine
minimeccanica 8 years ago
Any figure about the V and I you have drawn?
chadeau 11 years ago
RedstoneM 8 years ago
1N4007 is great
nerd7473 10 years ago
how do I do this with a prototyping breadboard?
not the solderless
Simply solder it? (solderless ones are better from my opinion)
Pointy 11 years ago
