Sticker-free Rubik's Cube!
Intro: Sticker-free Rubik's Cube!
Tired of the stickers falling off of your Rubik's cube? Here is a simple and cheap solution to making your cube last longer and look cooler!
STEP 1: What You'll Need.
Scissors, a ruler, a pen, 6 different colored foam pads (the thinner the better), and brush on Krazy glue (I got the kind made for plastic and leather... etc).
STEP 2: Prep Your Cube.
Remove the stickers from your cube. Try to get as much of the stickyness off of the cube. I accomplished this using Goo B Gone.
STEP 3: Squares
Cut 9 squares from each color. Make sure that they fit on the cube without affecting the cubes rotation. You can use the ruler to make perfect squares but I found this almost impossible and too time consuming so I just eye balled them.
STEP 4: Glue on the Squares.
Using the super glue, brush on a THIN coat of glue onto the FOAM CUBES. Try to get as close to the edges as possible so that the corners will not raise after excessive use. Do one cube at a time or the glue will dry.
Be very careful not to get any on your hand... its called SUPER GLUE for a reason.
Place the foam cube onto the Rubik's cube. I worked from left to right, top to bottom and found it to be the easiest. Make sure you get the square centered on the first time, the glue dries very rapidly.
STEP 5: Let It Rest.
After all the cubes have been placed onto your Rubik's cube, let the glue dry for at least a half an hour before attempting to solve the cube.
STEP 6: Scramble and Solve!
Scramble and solve your new Rubik's cube!
23 Comments
trinai.dotytubbs 3 years ago
singerboy41 9 years ago
Somehow, despite the fact that you "eyeballed" it, It actually looks better than you would expect when you eyeball it. Good job. Might have to try this.
captain camo 10 years ago
guitarmonk15 12 years ago
juliaKen 12 years ago
micraman 12 years ago
splazem 13 years ago
vishalapr 13 years ago
target40 13 years ago
Mr.A-Z 14 years ago
Nicolas M 14 years ago
mrrshotshot 14 years ago
damasta 14 years ago
KnexFreek 14 years ago
bassclarinet23 14 years ago
Ebag123 15 years ago
RMConstruction 14 years ago
Letheyann 14 years ago
AzraelUK 15 years ago
sora005 15 years ago
